05-04-2009, 07:35 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | i dont thing so infinity support has not uploaded this file just go on infinity support use search option past ur file name in serch bar without .bin e.g Mt256_th_pcb01_gprs_mt6225_s00.mt256_th_0716_mp_v0 7 click on search u will find his file 100 % sure |
The Following User Says Thank You to cel_phon For This Useful Post: |
05-04-2009, 07:36 | #3 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
05-06-2009, 19:28 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! from my side i can confirm: we dont have this flash file in our collection. What problem with this phone? have you tried to solve it by Format FFS? |
05-07-2009, 02:06 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: GSMPHILIPPINES
Member: 580978 Status: Offline Thanks Meter: 35 | hang but now no power sir try to format forget to read fullflash i need to revive this COM67 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B403:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:FFBFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 01227E22202200:FFBFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs/eeprom size detection error: can't detect ffs/eeprom address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:FFBFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.15C737A1.[MT256_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V0 7.BIN_3A59B23E].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.15C737A1._MT25 6_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V07.BI N_3A59B23E_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.15C737A1.[MT256_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V0 7.BIN_3A59B23E].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.15C737A1._MT256_TH_PCB01_GPRS_MT6225_S00.MT256_T H_0716_MP_V07.BIN_3A59B23E_.rpl ==================== warning: unknown identification#1 structure: MT256_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V0 7.BIN_3A59B23E error: Unknown firmware detected (v.2.81, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: MT256_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V0 7.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 01227E22202200:FFBFFF00000000 Write: Firmware |
05-07-2009, 20:47 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! phone must be flashed with ***, working flash file "MT256_TH_PCB01_GPRS_MT6225_S00.MT256_TH_0716_MP_V 07" unfortunately, we dont have this flash file in our collection. can you find same working phone on local market? |
need flash file for 6300 Q7 | shazrenda | SpiderMan | 3 | 05-18-2010 12:32 |
i neded flash file for 6300 dual sim | elhadi110 | Chinese Models & Cloned Phones | 5 | 03-05-2010 15:18 |
plz i need flash file for 6300 new sw | goldenploto | Infinity-Box | 2 | 02-24-2009 18:14 |
need flash file for 6300 type q7+ | khan_mobiles | Chinese Models & Cloned Phones | 1 | 08-05-2008 13:50 |
need flash file for 6300 | Nikil | Nokia Base Band 5 ( BB-5 ) | 3 | 04-27-2007 18:41 |
