02-28-2009, 10:42 | #1 (permalink) |
Major Poster Join Date: Feb 2008 Location: gsm codes
Member: 699036 Status: Offline Thanks Meter: 4 | j132 unlock 100% ok with infinity i have unlock 4 piece of j132 with the best box infinity thx for the great team COM6 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090228-103936.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 91 sec Remove/Install battery now ! |
The Following User Says Thank You to prounlocker For This Useful Post: |
02-28-2009, 21:00 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
03-05-2009, 10:56 | #5 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | Hello friend i try to unlock 2 phones but no respons by using cabel lg c2500 tell me what calbel u use for unlocking. |
The Following User Says Thank You to themobileshop For This Useful Post: |
03-05-2009, 16:12 | #6 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
Nokia 5800 v31 unlocked 100% ok with cyclone bomb | Punto-Móvil | Nokia Base Band 5 ( BB-5 ) | 0 | 03-24-2010 12:56 |
6120c Unlock Done 100% Ok With UB | GsmUniversal | Universalbox | 0 | 04-01-2009 15:48 |
now vodafone228fm by zte with counter blocked unlock ok with infinity | genci titi 2002 | Infinity-Box | 2 | 01-19-2009 13:44 |
Kg270 Dead 100% Ok By Infinity | manA007 | Infinity-Box | 1 | 09-02-2008 12:37 |
Motorola C139 Cingular Unlock Ok With Infinity | sahil2000ind | Infinity-Box | 12 | 11-01-2007 18:37 |
