07-30-2008, 16:19 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
AND YOU SERCH YOUR FILE SIGMATEL S1 FILE IN SUPPORT AREA IT IS AVABLE. | |
07-31-2008, 10:51 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is file name, here we cant see firmware version. ussually CM create file with this name when flash is completely erased. please try to find in logs what was original software version |
08-01-2008, 06:35 | #4 (permalink) |
Insane Poster Join Date: Jul 2005 Age: 52
Member: 165899 Status: Offline Thanks Meter: 17 | thanks for replay COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1203:000E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash_20080801-104718.B0M.bin Finished, time used: 1296 sec Remove/Install battery now ! |
08-13-2008, 16:49 | #13 (permalink) | |
I Think This File Not In Support Area. What Is Your Problem ? And Why You Flashing The Phone ? Just Format Phone. Chinish Phone 90% Solution Format. | |
need 2100 PM file very urgently | classic mobiles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-18-2009 15:44 |
7360 PM file very urgent pls :( | asadon5 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 03-20-2007 13:15 |
1600 PM file very urgent | naseer_10_1980 | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 03-15-2007 17:31 |
PLS Need C139 french LP flash file very Urgent!!!! | ReyTech | Motorola ODM | 7 | 11-02-2006 17:02 |
C55 URGENT!! need 1 logfile!! very urgent | SADESURF | Phone Unlocking Codes & Maps | 1 | 05-26-2003 08:59 |
