Old 05-19-2011, 07:01   #1 (permalink)
haroon454's Avatar
Member: 653398
Thanks Meter: 669
Nasaki m505 call yes no problem
COM9 [VCP0] selected
module v3.30
Device: Autodetect 6253 NOR
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00BB]: 0001:007E00630001 [SPANSION] S29VS128R_T
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
detect custom parameters...
detect project-id...
project-id: C100A3.XT.NASAKI01.110308.01
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100A3_XT_ NASAKI01_110308_01.BIN
project-id: C100A3.XT.NASAKI01.110308.01, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.30, database date: 11.05.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 16Mb
number of areas/bytes to read: 1:01000000
file saved: C:\InfinityBox\ChineseMiracle\TELSDA53_SLIM_09A_PC B01_GPRS_MT6253_S00.C100A3_XT_NASAKI01_110308_01__ fullflash_20110519-101836.B0M.bin
Format...
Disconnect...
done
Finished, time used: 5 min 3 sec
Remove/Install battery now !
i try flash and format but problem still
Old 05-19-2011, 09:00   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Could you write your problem in more detail, it's confusing!
I guess the phone has calling problem.
Repair imei and try to call emergency number without sim card.
If it fails to call then phone has hardware problem.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 05-21-2011, 12:16   #3 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
i think your means when incoming call yes button not working?
Old 05-24-2011, 09:23   #4 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello yes bro u understood thats mean but he said now he is return to customer in same problem.....
Old 05-25-2011, 05:12   #5 (permalink)
haroon454's Avatar
Member: 653398
Thanks Meter: 669
yes when her calling me then not working green or red button
Old 05-26-2011, 04:35   #6 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
This is hardwere Problem...............................
Old 05-26-2011, 13:48   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Yes, this is due to hardware fault.
Wr.
Old 11-27-2011, 17:57   #8 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Wr.
I have same problem in nasaki b3,Yes/green and end button not work on incoming call,would you like to mention which area need to be check in hardware? thanks in advance
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.20677 seconds with 9 queries
