03-09-2010, 15:29 | #1 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | need G-Five U-888 flash file- I need G-Five U-888 flash file. Since the original flash file has been replaced by someone else who was not expert as he was trying to flash the set so I don't know the original version. The set has come to me in dead position. If someone has good file plz upload it to 4shared or any other file hosting (other than rapidshare). Thanx and regards. |
03-09-2010, 22:01 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
I think it is U808 refer to - http://forum.gsmhosting.com/vbb/f425/one-method-find-flash-file-infinity-support-site-499453/ | |
The Following User Says Thank You to srinibas For This Useful Post: |
03-10-2010, 09:52 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Yes sure it is U888, here is the pic attached- [IMG][/IMG] and I tired to flash it but set didn't get on, here is the log- COM11 [VCP3] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905_16m_En_Fr_Tr_Hi_Urdu_Farsi_Pt _Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E803:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong data size at 0x00002FC0, retry... read error recovered warning: wrong data size at 0x000087C0, retry... warning: wrong data size at 0x000087C0, retry... read error recovered warning: wrong data size at 0x0000E3C0, retry... warning: wrong data size at 0x0000E3C0, retry... read error recovered warning: wrong data size at 0x0002BBC0, retry... read error recovered search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905.BIN project-id: MAUI.08B.W08.52.MP.V2.090905, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905__ffs... warning: wrong data size at 0x00E12C00, retry... read error recovered warning: wrong data size at 0x00E1EC00, retry... read error recovered warning: wrong data size at 0x00E2A800, retry... read error recovered warning: wrong data size at 0x00E42800, retry... read error recovered warning: wrong data size at 0x00E48400, retry... read error recovered warning: wrong data size at 0x00E4E000, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING25_08B_GEMI NI_PCB01_GPRS_MT6225_S00.MAUI_08B_W08_52_MP_V2_090 905__ffs_20100310-134040.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 18 min 4 sec Remove/Install battery now ! |
China G-Five Model-T580 flash file want | AtharavK | Chinese Models & Cloned Phones | 1 | 04-27-2010 08:13 |
usb smart L7 flash need is no in support flash files l7 help | davor2003 | Motorola P2K (USB-Smart) | 0 | 04-07-2006 21:15 |
Need Nokia 7190 old full flash file ! | Supergsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-10-2001 16:13 |
Need nokia 6110 v4.33 flash files | Arnis A | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-02-2000 17:09 |
