12-03-2014, 20:02 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Release) MTK/MediaTek v1.07 MediaTek SP Platform .Universal NAND support for MT6571/MT6572/MT6575/MT6577 released * .MT6573 support released (Read Info/Read Flash/Format FS) .MT6575/MT6577 NAND support fixed .MT6575/MT6577 eMMC support improved .Repair Security improved Other: .Flash Pre-Erase revised .Format FS procedure revised for eMMC phones ( simplified and removed extended settings ) ** .Added support for "Format FS" on non-aligned PMT phones ( Some MT6575 eMMC phones, like - Alcatel, Lenovo and some MT6573 NAND ) .FlashInit improved .Compile Info extraction improved .MT6575/MT6577/MT6573 NAND Compile Info extraction enabled .FlashID database updated MediaTek FP Platform .Reset user code operation improved .FlashId database updated Other: Some bugfixes and improvements Notes : * It is mandatory now make "Read Info" before other operations for NAND phones ** If need full rest ( "Wipe"/"Clean" ) - Set to "0" always. If need preserve some vendor apps - use software defined or own set. If phone "hang" on logo - do format again with "0" settings. Official download link: HERE Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter Last edited by YellowBoss; 12-03-2014 at 23:57. |
The Following 17 Users Say Thank You to YellowBoss For This Useful Post: |
12-04-2014, 02:01 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | until now the infinity still alive there no body break there records for free support nice update |
The Following User Says Thank You to maxieboy For This Useful Post: |
12-04-2014, 02:14 | #5 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Honduras
Member: 1532892 Status: Offline Sonork: 1603006 Thanks Meter: 44 | all time i love me infinity becouse are the king in china mobiles put in in time need support for spd what other tool dead after format , read info p, if you add this funtions all customers are happy !! |
The Following User Says Thank You to ejproduction For This Useful Post: |
12-04-2014, 06:14 | #10 (permalink) | |||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, it is supported and working few month already. Quote:
This feature repair all killed phones by other boxes as well, if inside not flashed other phones file. Quote:
Can you help us with locked samples? At least - dumps from them? It will be, but I want first finish some really need things. | |||
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
12-04-2014, 09:24 | #11 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello Dzirt, Got one Lava Iris 356 with MT6572 Nand cpu with pattern lock. I tried to "Read Info" but software stuck on- NAND : Detecting structure now... Please, wait. I waited more than 10 min. but result same- stuck, so I closed the software. even tried to read full flash but not worked. Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. Chinese Miracle II [MTK module] v 1.07 Start at : [12/4/2014 / 1:35:58 PM] Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Returned the phone to customer after hard reset manually. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
12-04-2014, 09:28 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Micromax X2814 read flash done- Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 2A097B12BCB657EE20EF49D0C1E93054 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FFE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : BESTONE60A_11B_PCB01_gprs_MT6260_S00.MMX_X2814_SW_ V0_0_14_HW_V_1_0_120914.bin FileVersion : MMX_X2814_SW_V0.0.14_HW_V_1.0_120914 Saved to : C:\InfinityBox\CM2MTK\Read_out\BESTONE60A_11B_PCB0 1_gprs_MT6260_S00.MMX_X2814_SW_V0_0_14_HW_V_1_0_12 0914.bin Br. |
12-04-2014, 10:06 | #13 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Seems as in next will be some init modes in settings (2-3 for nand), because I'm out of idea - not have such samples on hands yet. | |
12-04-2014, 10:20 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Lenovo P780 Lenovo P780 Read Ok Code: Card found: S/N C55****** Chinese Miracle II [MTK module] v 1.07 Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019064314734A3008604A14142C3 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3C34241A1 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Code: Operation : Repair Security [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! |
