Old 10-30-2016, 15:56   #1 (permalink)
Member: 1042248
Sonork: 100.1603905
Thanks Meter: 28
need help
q mobile a290 big problem
i have perfect firmware of a290
when i write firmware with cm2 give error not compatibility
write this file with sptool flashing complete but mobile no power on write backup file with cm2 flash complete mobile power on but not write new file i try more then 10 files but give compatible error
help me plzzzzz
Old 10-30-2016, 16:17   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,988
Strange !
perfect file not write with CM2 and write with SPTool but set not power on?
its mean , file not perfect
A290 have different firmware version
find/match correct file and flash phone
post result...
Old 10-30-2016, 17:07   #3 (permalink)
Member: 2372074
Sonork: 100.1663814
Thanks Meter: 78
check phone 2g 3g sptool try ver v3.1336.0.198 tested
Old 10-31-2016, 05:28   #4 (permalink)
Member: 1042248
Sonork: 100.1603905
Thanks Meter: 28
Originally Posted by syed tuqeer View Post
Strange !
post result...
dear my file perfect i write this file more then 20 mobile
and download 6 files again but all file no compatible
if u have givd me perfect firmware
Old 10-31-2016, 05:44   #5 (permalink)
Member: 1042248
Sonork: 100.1603905
Thanks Meter: 28
sir check this and tel whats difference file
Old 10-31-2016, 07:41   #6 (permalink)
Member: 2082450
Thanks Meter: 1,438
zaheerkhan2011,
A same mobile can have different hw and sw revision.
SO you may be trying flashing the phone with different sw ver, that's why CM2 said not compatible.
Between you can post here CM2 Identify logs for better help..
Old 11-01-2016, 07:34   #7 (permalink)
Member: 1042248
Sonork: 100.1603905
Thanks Meter: 28
here is logs
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473261110173E729CB42F7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A4834473261110173E729CB42F7
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xC34951B300CC9360F12AF226A43445CF
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : QMobile A290
ProdModel : QMobile A290
Device : QMobile A290
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP7.V1
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_txd
LCD [1] : hx8379c_fwvga_dsi_vdo_tcl
LCD [2] : ili9806e_fwvga_dsi_vdo_dj
LCD [3] : ili9806e_fwvga_dsi_vdo_glass
LCD [4] : ili9806e_fwvga_dsi_vdo_djnew
LCD Res : 854x480
TOUCH [0] : GT9XX
CAM [0] : ov5645_mipi_yuv
CAM [1] : ov5646_mipi_yuv
CAM [2] : sp0a19_yuv
CAM [3] : gc0329_yuv
CAM [4] : hi258_mipi_yuv
MODEM : mt6572_s5201ap_hspa_gemini_PK
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB ur_PK fa_IR hdpi -sw600dp -sw720dp
Done!
Elapsed: 00:00:10
Page generated in 0.22041 seconds with 7 queries
