Old 08-23-2018, 14:43   #1 (permalink)
Member: 931121
Thanks Meter: 91
need help
Card found : S/N : 64C1CE3F , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 700100454534454134012EB5BFFDC333
Initialize Memory ...
[DA_ERROR] : DA Load failed!
ErroCode : 0x2008
DA_LOAD_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:37
Reconnect Power/Cable!
lava iris 30 da file.
Old 08-23-2018, 14:46   #2 (permalink)
Member: 931121
Thanks Meter: 91
symphony v130 format not done pls help
Card found: S/N : 64C1CE3F , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 7.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 7.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 14 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : V130
Model Brand : Symphony
Model Device: V130
AndrVersion : 7.0
BaseBand CPU: SP7731CEA
CompileDate : 1/17/2018 12:19:04 PM
Project Ver : V130_HW1_V7
Model Ext : V130
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:30
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Error!
ERROR : PART_FORMAT failed!
Page generated in 0.19615 seconds with 7 queries
