04-13-2008, 19:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Message of William Branham
Member: 239523 Status: Offline Thanks Meter: 210 | need help I got the file this file from support: MTK26_05C_DS500DA_TRFAE_PCB01_GPRS_MT6226_S01.MAUI _05C_W06_16_16m_En_Ru_Fr_Th_Ar.B0M and this CM_Nokia-N95-2x6pin_MTK26_05C_DS500DA_TRFAE_PCB01_GPRS_MT6226_S 01.MAUI_05C_W06_16_16m_En_Ru_Fr_Th_Ar.B0M and flashed the phone but it starts up but with wite screen. is there any solution??? |
04-13-2008, 19:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity-Box: How to repair "White LCD", "Black LCD", "no LCD" problems: 1. check phone hardware: LCD unit may be damaged. 2. check phone hardware: LCD flex cable may be damaged. 3. use other flash files for flashing, because exist many different phones with different LCD hardware types so need to use different firmware files and find firmware that work good for your LCD hardware. Select flash file with similar firmware version, phone model name is not important, only firmware version is important. |
04-13-2008, 20:18 | #3 (permalink) |
Member: 239523 Status: Offline Thanks Meter: 210 | dear sir the phone was only restarting. lcd was ok but after flashing it is now wite screen. I flashed with the above firmware which are same like what was in phone but still wite screen. |
04-13-2008, 21:46 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, make search in this forum. Several days ago I have made really big, easy and very clear explanation regarding firmware versions, it's difference and many other things. |
04-13-2008, 22:22 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If you will read this http://www./showthread.php?t=523104 you will understand more |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
samsung T429 T MOBILE FLASH I NEED HELP | who_i | UST Pro II | 1 | 08-17-2010 14:30 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
2700 flashing need help | ngaia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 11:48 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
