Old 08-23-2009, 11:41   #1 (permalink)
Member: 252178
Sonork: 100.1582561
Thanks Meter: 123
iphone range check error
COM8 [VCP0] selected
module v2.90
Device: Autodetect 6228-6230 NAND
Checking data, wait...
Action: read NAND flash
read mode: 01
Boot ...
19200 fixed
Connecting, wait...
Initializing [6230:8A02:8A02]...
CPU: MT6230
high speed boot On
chip: 0031:000F:0101
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.02
cpu-id: 0C
loader: 3.0840.00.00
NAND id: EC795A3F
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 2000
external ram: 00000000
finalize connection...
done
emi configuration...
ram size: 04000000
emi configuration done
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
NOR: 0000:000000000000 [00000000]
NAND: 00EC:0079005A003F [08400000]
NOR chip is not installed
Initialize Done
Set baud ...
460800
Set baud Done
Identification ...
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
reading bootloader structure area (00010000 bytes)...
detecting bootloader structure...
source data: page only
rom info protocol ver: 04
ver. sw 1: APL228_PCB03_GPRS_MT6230_S02.APL228_20081218_V1_3. BIN
ver. sw 2: APL228_20081218_V1.3, 00000000
ffs offset/size: 02000000/06000000
id-page1 Ok
Old 09-12-2009, 15:04   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
module v2.90
read mode: 01
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6230
high speed boot On
status: FF
Boot Done
Initialize ...
version: 3.02
cpu-id: 0C
NAND id: EC795A3F
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 2000
done
ram size: 04000000
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
Initialize Done
Set baud ...
460800
Set baud Done
Identification ...
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
id-page1 Ok
hi all and supporters..
i have the same pn on 6228 NAND cpu.. range check error..
Old 09-13-2009, 20:47   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we know about this problem and working under improving it
update will follow nearest time
Old 09-13-2009, 21:33   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hello!
thanx sir...
we will be wait for it..
Old 10-27-2009, 21:13   #5 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Any news about range check error fixing?Have an Iphone C900 on hand and range check error problem when detecting this
detect standard fat offset pass #1...
detect standard fat data...
Old 10-28-2009, 02:20   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, try to use latest software.
Let's see results.
Old 10-28-2009, 10:02   #7 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Originally Posted by InfinitySupport View Post
Hello,
Let's see results.
Used the latest software the same error.Such errors appear mostly in 6225 based phones I think
Old 10-28-2009, 12:41   #8 (permalink)
Member: 130995
@systemworm
please, post here operation log or attach screenshot so we will be able to see where is the problem exactly.
Thanks !
Old 10-28-2009, 20:49   #9 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Here is the log.
==== log opened: [10/27/2009 11:54:03 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe
Loading data, wait...
[Infinity Box] Chinese Miracle v2.93
S/N: ****:0112
Wait...
Device: Autodetect 6205-6227 NOR
Done
==== log: [10/27/2009 11:54:35 PM] ====
COM6 [VCP0] selected
module  v2.93
Action: "sp-unlock"
unlock method: standard fast
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8503:0006
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
ver. sw 1: E800_PXHT1F12_EVCOM2_MT6225S00.01_1_20090617.BIN
ver. sw 2: E800_PXHT1F12.01.1, 00000000
ffs offset/size: 01C00000/00400000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
detect standard fat location pass #1...
==== log opened: [10/28/2009 12:06:31 AM] ====
[Infinity Box] Chinese Miracle v2.95
S/N: ****:0112
Wait...
Done
==== log: [10/28/2009 12:06:59 AM] ====
module  v2.95
advanced flash detection disabled
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
error: can't detect CPU id
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 29 sec
Remove/Install battery now !
==== log: [10/28/2009 12:07:48 AM] ====
module  v2.95
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
flash: Samsung D 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
searching rom info...
search rom info finished
TCL-ID is absent
address offset: 00000000
ffs/eeprom chip: 00
The Following User Says Thank You to systemworm For This Useful Post:
Old 02-10-2011, 22:53   #10 (permalink)
Member: 1101696
Sonork: 361899
Thanks Meter: 6
help!!!
@systemworm
Thanks !
hepl me.....................
Old 02-13-2011, 19:21   #11 (permalink)
Member: 148515
hello!
will gladly help, please post your Log
Help china iphone copy 6230 NAND range check error pitikor Infinity-Box 2 09-13-2009 20:47
motorola C168 range check error vertex777 Infinity-Box 1 07-07-2008 21:23
Range Check Error vijeeshkannur Infinity-Box 4 03-26-2008 15:13
C118 range check error green bird Infinity-Box 1 02-13-2008 18:54
Page generated in 0.27508 seconds with 10 queries
