09-04-2009, 22:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Karachi,Pakistan Age: 34
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | Need help about Infinity box |
09-05-2009, 00:30 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 406 | Quote:
Then select the type C:\Program Files\InfinityBox\pinout C:\Program Files\InfinityBox\PinFinder | |
09-05-2009, 17:54 | #3 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
need help urgent.infinity box! | sas-pc | Infinity-Box | 1 | 07-06-2008 23:03 |
Need Help about UB box (Urgent) | cronicle861 | Universalbox | 4 | 06-19-2008 03:16 |
need help about my box | shawgsm | Multi-Box | 9 | 09-27-2006 11:28 |
need help about update box , mine is 2.51 , sn stolen by someone | GYZMO | Griffin | 1 | 02-15-2005 13:31 |
need help about griffin box | Bi0H4z4rD | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 10-20-2004 11:45 |
