11-21-2015, 07:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | need help about this topic Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020DD2EF373187 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020DD2EF373187 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Stellar ProdName : MI-438 ProdModel : MI-438 Device : Spice AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : Spice_MI-438_IND_Ver10.0_140315_1443 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_P44_1_wg_n EXTRA : LCD [0] : hx8379a_wvga_dsi_vdo LCD [1] : ili9806e_dsi_vdo LCD Res : 800x480 TOUCH [0] : nt11004 TOUCH [1] : ft6x06_focaltech CAM [0] : gc0328_yuv CAM [1] : gc0329_yuv CAM [2] : nt99252_yuv MODEM : wingtech72_wet_jb3_hspa_pasky77590_band15_wt97602_coclk LOCALE : en_US hi_IN bn_IN ar_IL hdpi Done! Elapsed: 00:00:10 Reconnect Power/Cable! and one more few day ago one more set come mmx A110 same problem so flash with cm2 so set is not compleat flash and set dead and not recover .... just inform ... thanks advance |
11-21-2015, 08:24 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. Format FS/ Repair ExtData. Not help? Change eMMC. 2. Change eMMC or flash correct FW , without logs just a thoughts. |
11-21-2015, 08:50 | #3 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, @@@@___@@@ Did You Try With "Reset Phone" ?. I Faced Many Times In Alcatel Cellphones, After Click On "Reset Phone" Set Erase Something Then Power On & Working Fine. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
