01-08-2008, 22:15 | #1 (permalink) |
Registered User Join Date: Jul 2003 Age: 43
Member: 34599 Status: Offline Thanks Meter: 12 | need help br in back cover write ztc zt989 and in front write n82 with 2x6 conector pin out. if i found the pinout which one i can use in ztc directory because no one match inside. very neares type in ztc directory just zt 898 zt 988 zt 999 zt 989 not found.ill try with thats 3 type but couldnot detect. pls u help infinity team. thx |
01-08-2008, 23:12 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! start from opening phone and check if there is marked test points on PCB. also make sure it is MT procesor based phone if there is no such points- check with multimeter where is located GND pin in your phone post here, i will try to help |
01-09-2008, 18:39 | #3 (permalink) |
Member: 34599 Status: Offline Thanks Meter: 12 | br no marked test point on pcb. pin is 2x6 /1 2 3 4 5 6\ i i !7 8 9 10 11 12! ground is 2 and 9 pin. just 3 pin have output 2,8/2,7 v its pin 4 ,5 and 9. i think rx is 4 and tx 5. i just dont know which one to select in ztc folder because no one match. phone is ztc n82 zt989. need u help. thx |
01-10-2008, 22:35 | #6 (permalink) |
Member: 34599 Status: Offline Thanks Meter: 12 | n82 2x6 pin mini ztc989 restar with sim card solved log: Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:7BC1:18F6 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: YH628_ZY_BT_FM_MULTILANG_V010 Version: MT26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35440500404523 connection Ok building list... done items to clear: 196 130 of 196 items cleared 0 items remains Finished, time used: 329 sec Remove/Install battery now ! n82 zt989 2x6 pin mini not power on solved log: COM8 [VCP15] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:C18C:3A88 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: FIREFLY_PCB02_GPRS_MT6226_S01.YH628_ZY_BT_FM_MULTI LANG_V010.BIN ver. sw2: YH628_ZY_BT_FM_MULTILANG_V010 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[FIREFLY_PCB02_GPRS_MT6226_S01.YH628_ZY_BT_FM_MULTI LANG_V010.BIN]]... file saved: G:\INFINITY\infinity\BACK UP USER\n82_ztc_zt989 2x6_mini conector\backup_eeprom_n82_ztc_zt989_yg matol_[FIREFLY_PCB02_GPRS_MT6226_S01.YH628_ZY_BT_FM_MULTI LANG_V010.BIN]_20080111-030503.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware Write Done Finished, time used: 441 sec Remove/Install battery now ! |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
k810 lcd got line....pls help br.. | arrow1339 | Sony Ericsson Hardware Repair | 0 | 05-17-2009 08:50 |
