01-27-2012, 22:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: On the internet Age: 95
Member: 1383120 Status: Offline Sonork: 100.1612024 Thanks Meter: 18 | need help with coral 645 imei repairs module v3.75 Device: Coral-645 Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 new imei: 351608042522933 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F27:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required startup code area #1 record #2 is damaged, recalculation required rom info detection finished device-id: DE962DC2 rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN project-id: C2019_1.25_0x1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690 , 17049DF4 code offset: 00000000 ffs offset/size [01]: 00B40000/004C0000 rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent ffs/eeprom address assigned: 00B40000 startup code area #1 check... rpl file not found: c:\InfinityBox\MModule\id.DE962DC2.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _F49D0417].rpl rpl file not found: c:\InfinityBox\MModule\id.DE962DC2._CELLONSZ23C_09 A_GEMINI_PCB01_GPRS_MT6223P_S00.C2019_1_25_0X1110F _DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN_F49D0417_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 .[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _F49D0417].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 ._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2 019_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.B IN_F49D0417_.rpl ==================== warning: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _F49D0417 Unknown firmware found (v.3.75, database date: 12.02.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== rpl file not found: c:\InfinityBox\MModule\id.DE962DC2.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _C4E34DFB].rpl rpl file not found: c:\InfinityBox\MModule\id.DE962DC2._CELLONSZ23C_09 A_GEMINI_PCB01_GPRS_MT6223P_S00.C2019_1_25_0X1110F _DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN_C4E34DFB_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 .[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _C4E34DFB].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 ._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2 019_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.B IN_C4E34DFB_.rpl ==================== warning: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN _C4E34DFB Unknown firmware found (v.3.75, database date: 12.02.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Coral-645_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00. C2019_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690 __ffs... file saved: C:\Documents and Settings\Triple\Desktop\Coral-645_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00. C2019_1_25_0X1110F_DIGICEL_SAMSUNG_TRULY_HY_OV7690 __ffs_20120127-164602.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 2 min 54 sec Remove/Install battery now ! |
01-28-2012, 17:01 | #3 (permalink) |
Member: 1383120 Status: Offline Sonork: 100.1612024 Thanks Meter: 18 | COM19 [Serial2] selected module v3.75 Action: "repair imei" imei write method: mode-2 new imei: 351608042522933 Model: Coral-645 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F27:000C status: FF Connecting at 19200, wait... warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 2 min 17 sec Remove/Install battery now ! |
01-28-2012, 17:08 | #4 (permalink) |
Member: 1383120 Status: Offline Sonork: 100.1612024 Thanks Meter: 18 | now coral 645 dead after full flash COM19 [Serial2] selected module v3.75 Device: Coral-645 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Coral-645_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00. C2019_1_24_0X1110F_D__fullflash_part_1_of_1_201009 18-111042.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Coral-655_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00. C2019_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690__f fs_20100918-113641.B0E.bin ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F27:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required startup code area #1 record #2 is damaged, recalculation required rom info detection finished device-id: DE962DC2 rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN project-id: C2019_1.24_0x1110F_DIGICEL_SAMSUNG_VL_HY_OV7690, 917FC5A7 code offset: 00000000 ffs offset/size [01]: 00B40000/004C0000 rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent ffs/eeprom address assigned: 00B40000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (general #0)... done firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: c:\InfinityBox\MModule\id.DE962DC2.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_A7 C57F91].rpl rpl file not found: c:\InfinityBox\MModule\id.DE962DC2._CELLONSZ23C_09 A_GEMINI_PCB01_GPRS_MT6223P_S00.C2019_1_24_0X1110F _DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_A7C57F91_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 .[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_A7 C57F91].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 ._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2 019_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_ A7C57F91_.rpl ==================== warning: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_A7 C57F91 Unknown firmware found (v.3.75, database date: 12.02.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== rpl file not found: c:\InfinityBox\MModule\id.DE962DC2.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_C4 E34DFB].rpl rpl file not found: c:\InfinityBox\MModule\id.DE962DC2._CELLONSZ23C_09 A_GEMINI_PCB01_GPRS_MT6223P_S00.C2019_1_24_0X1110F _DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_C4E34DFB_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 .[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_C4 E34DFB].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.DE962DC2 ._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2 019_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_ C4E34DFB_.rpl ==================== warning: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN_C4 E34DFB Unknown firmware found (v.3.75, database date: 12.02.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 9_1_24_0X1110F_DIGICEL_SAMSUNG_VL_HY_OV7690.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: EC240200000000:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC240200000000:2AEA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2AEA0000000000 Finalization Done Finished, time used: 4 min 37 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-29-2012, 14:13 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! phone can not be finalized. Download latest Mmodule and repeat. When you finally recover your phone- show me IMEI change mode-1 log. this is best method for IMEI change. Even if phone can not be detected, you still can change IMEI with this method over Bluetooth connection: IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum or you can enable UART in Engeneering menu and change by cable |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
