Old 10-30-2007, 19:31   #1 (permalink)
Member: 364696
Thanks Meter: 16
Need Help DVD S618
hi Team I gov a Chinese mobile with lable Dvd S618
it start like this
when we power on, it shows counting 1..100 then gose off
when get full info its ok
OM3 [VCP0] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: NAND reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip-id: 0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND: Samsung K9F1G08X0M 2048+64 64 pages, 132Mb
NAND id: ECF18015
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00EC:00F100800015 [08400000]
warning: NOR flash chip not supported or not detected
Initialize Done
Set baud...
230400
Set baud Done
Identification...
converting data...
done
protocol ver: 04
ver. sw1: SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN
ver. sw2: SHINEC_S2_IL9221_V2.2
ffs offset/size: 02000000/06000000
id-page Ok
nfi area detection finished: Ok
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.27EADFDB.[SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN_B202C57C].rpl
New firmware detected: SHINEC28_06A_PCB04_GPRS_MT6228_S02.SHINEC_S2_IL922 1_V2_2.BIN
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification detection finished
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_27EADFDB_SHINEC28_06A_PCB04_GPRS _MT6228_S02.SHINEC_S2_IL9221_V2_2.BIN_B202C57C_200 71029-103300.B4X.bin
Finished, time used: 78 sec
Remove/Install battery now !
safe form
COM3 [VCP0] selected
19200
Initializing[6228:8A02]...
Connecting, wait...
error: can't finalize test moide
Operation failed !
Finished, time used: 21 sec
it format complete ok after complete formatting phone is in same position
but when we get detailes info it gives
Action: read/check detailed information
Boot...
19200
Connecting, wait...
chip-id: 0000:0101
Boot Done
Initialize...
version: 3.1
NAND id: ECF18015
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
Initialize Done
Set baud...
230400
Set baud Done
Identification...
converting data...
done
protocol ver: 04
id-page Ok
error: unexpected answer:
identification data damaged
Finished, time used: 263 sec
now can i flash it
Old 10-30-2007, 21:14   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
Yes... I completely agree with you... Let's all together ignore text from software log window !
Can you flash ? Yes... But phone will be dead after flashing.
Why ? because everybody ignore text in software log window.
Old 11-01-2007, 19:41   #3 (permalink)
Member: 364696
Thanks Meter: 16
sir plz tell me
what i do i mean can i flash it if yes then from where i get flash file.
i have already send back up files to team support with lable text on phone but team did not respond me.
i m waiting for reply and flashfiles.
can i flash me phone with backup files
thanks team
Old 11-01-2007, 23:58   #4 (permalink)
Member: 130995
where you have sent files ?
What files exactly was sent ?
correct mail for flash files: [email protected]
Old 11-02-2007, 09:59   #5 (permalink)
Member: 364696
Thanks Meter: 16
sir
i have send the following files to ur mail address metioned above
Old 11-02-2007, 10:19   #6 (permalink)
Member: 130995
Yo will be able to flash phone with this firmwae in next Infinity-Box update.
Also you can try to use other flash files with firmware version name like SHINEC28..., only firmware version is important criteria, not phone model name.
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriousGold 66 08-27-2010 14:20
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 11:56
nokia masters need help.............. ANILMPLY Nokia Hardware & Hardware Repair 0 03-29-2010 11:48
DVD s618 Benzee76 Infinity-Box 7 07-22-2008 00:09
Mark Levinson Dvd Player... Need Help! Saff CAR Electronics 0 11-27-2007 22:41
Page generated in 0.29899 seconds with 8 queries
