12-28-2017, 21:55 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Need help with this error , Flashing , Read Info , Init Preloader but still same Customer says that was damaged while flashing with flash tool (maybe he lie) Any Way i read somewhere in forum that this error mean that preloader is not compatible with it, in this case phone has erased preloader. Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004545344544340106D1656864B7 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! |
12-29-2017, 07:19 | #2 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hi, Just want to see how you could manage to flash this phone in this stage?? Quote:
12-29-2017, 08:14 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | DA can't initialize DRAM with given settings ( from fw, prealoder ) If you try different files - seems as there is eMCP problem ( it should be combined emmc+ram ) |
01-12-2018, 14:23 | #4 (permalink) | ||
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Guys sorry for late reply , was out of country @chandanps18 Same message on HW Test @JayDi I Got another set Sanno S7, Customer was in another store to remove user code. Service mistake now i am getting same error. Probably something is erased dont know. Log from Sanno S7 that was in good condition (so no HW Failure) After try to remove code (not with cm2 - some other store) I m getting Code: Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454534454134012F183E8A53CD Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! | ||
01-13-2018, 03:54 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That error just indicate about not found dram init data in database. If you select this fw : WIKO K-KOOL V2800AN or device original one - it will pass init in bootrom mode. |
01-13-2018, 20:28 | #6 (permalink) | ||||
Now , after i use suggested Firmware it will hang on repartition , its normall because i use other flash suggested by you Quote:
Thanks in Advance | ||||
The Following User Says Thank You to Formingus For This Useful Post: |
01-13-2018, 20:38 | #7 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Additional Information Copied wiko preloader to sanno s7 firmware folder Renamed preloader to match sanno s7 scatter Generated checksum and flash is ok But set only will power on and remain like when we flash wrong lk.bin Bright Blue screen with led indicator Quote:
