Need Help From The Experts Who Flash Kg110 Successfully Hello Friends And Infinity Team Any Body Successfully Flash The Kg 110 With Out Errors I Mean I Flashed 2 Phones With Infinity But Both Got Same Problem Like Dots Over The Display And Also Restarts Frequntly.now Also I Got Some Problem, That Is Imei Currepted.i Cant Dare To Flash Because It Will Be Dead.if Any Body Did Successfully Please Tell Me What Version Should I Take. |
SEE THE LOG I ALREADY FLASH 2 PHONE WITH INFINITYBOX ==== log opened: [9/27/2007 4:07:42 PM] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.21 S/N: 2143:010A Wait... Current device: LG KG110 Done Loading file v.02... KG110P40FL-91-V10a-404-XX_2006-09-29_Code.B1M.bin loaded Loading file v.02... KG110P40FL-91-V10a-404-XX_2006-09-29_Alchemy_En_Fr_Tr_Pt_Es_Hindi_Marathi.B1P.bin loaded Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352691014930283 file saved: backup_eeprom_352691014930283_LG KG110_20070927-160952.B1E.bin Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1068 sec Remove/Install battery now ! ----------------------------------------------------------------------------------------- THIS IS LOG DEAD LG KG110 -- FLASHING COMPLETE N PHONE GET ALIVE AGAIN ----------------------------------------------------------------------------------------- ==== log opened: [10/27/2007 3:33:11 PM] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.22 S/N: 2143:010C Wait... Current device: LG KG110 Done WARNING ! Settings will be cleared, user data erased ! Make eeprom backup before this operation ! Continue ? Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: reset Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352691012497764 current otp imei: 352691012497764 file saved: backup_eeprom_352691012497764_LG KG110_20071027-153424.B1E.bin ........ version: XXX-XX V10i ARB KG110P40 Reading[XXX-XX V10i ARB KG110P40_eeprom-ffs_352691012497764_LG KG110]... file saved: backup_XXX-XX V10i ARB KG110P40_eeprom-ffs_352691012497764_LG KG110_LG KG110_20071027-153836.B1E.bin Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 297 sec Remove/Install battery now ! Loading file v.02... KG110P40FL-91-V10a-404-XX_2006-09-29_Code.B1M.bin loaded Loading file v.02... KG110P40FL-91-V10a-404-XX_2006-09-29_Alchemy_En_Fr_Tr_Pt_Es_Hindi_Marathi.B1P.bin loaded Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! error: unexpected answer during boot procedure Boot Fail error: no any expected answer Finished, time used: 18 sec Remove/Install battery now ! Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... error: boot failed: 3B possible error: Power key released too fast, need to keep Power key pressed during boot procedure. Release Power button ! error: unexpected answer during boot procedure Boot Fail error: no any expected answer Finished, time used: 8 sec Remove/Install battery now ! Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! error: unexpected answer during boot procedure Boot Fail error: no any expected answer Finished, time used: 19 sec Remove/Install battery now ! Testing COM6 at 115200... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352691012497764 current otp imei: 352691012497764 file saved: backup_eeprom_352691012497764_LG KG110_20071027-164722.B1E.bin ........ version: XXX-XX V10i ARB KG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1106 sec Remove/Install battery now ! -------------------------------------------------------------------------------------- THIS IS LOG LG KG110 CAN BOOT/FREEZE - FLASHING COMPLETE N PHONE GET ALIVE AGAIN ---------------------------------------------------------------------------------------- |
Mate! 1st connect your phone then Flash your phone following file 1- KG110P40-20-V10b_602-03_MAY-31-2007_code 2- KG110P40-20-V10b_602-03_MAY-31-2007_alchemy_Arabic Then only go to Service option connect your phone again then press Reset settings option your phone live. |
