Old 10-29-2007, 13:19   #1 (permalink)
Member: 300690
Thanks Meter: 12
Need Help From The Experts Who Flash Kg110 Successfully
Hello Friends And Infinity Team Any Body Successfully Flash The Kg 110 With Out Errors I Mean I Flashed 2 Phones With Infinity But Both Got Same Problem Like Dots Over The Display And Also Restarts Frequntly.now Also I Got Some Problem, That Is Imei Currepted.i Cant Dare To Flash Because It Will Be Dead.if Any Body Did Successfully Please Tell Me What Version Should I Take.
Old 10-30-2007, 12:02   #2 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
SEE THE LOG I ALREADY FLASH 2 PHONE WITH INFINITYBOX
==== log opened: [9/27/2007 4:07:42 PM] ====
Application: C:\Program Files\InfinityBox\LGA\LgA.exe
Loading data, wait...
[Infinity Box] v1.21
S/N: 2143:010A
Wait...
Current device: LG KG110
Done
Loading file v.02...
KG110P40FL-91-V10a-404-XX_2006-09-29_Code.B1M.bin loaded
KG110P40FL-91-V10a-404-XX_2006-09-29_Alchemy_En_Fr_Tr_Pt_Es_Hindi_Marathi.B1P.bin loaded
Testing COM6 at 115200...
COM6 [VCP0] selected
Device: LG KG110
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
"keep calibration" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 352691014930283
file saved: backup_eeprom_352691014930283_LG KG110_20070927-160952.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 1068 sec
Remove/Install battery now !
THIS IS LOG DEAD LG KG110 -- FLASHING COMPLETE N PHONE GET ALIVE AGAIN
==== log opened: [10/27/2007 3:33:11 PM] ====
[Infinity Box] v1.22
S/N: 2143:010C
Wait...
Done
WARNING ! Settings will be cleared, user data erased !
Make eeprom backup before this operation !
Continue ?
Device: LG KG110
Action: reset
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 352691012497764
current otp imei: 352691012497764
file saved: backup_eeprom_352691012497764_LG KG110_20071027-153424.B1E.bin
version: XXX-XX V10i ARB KG110P40
Reading[XXX-XX V10i ARB KG110P40_eeprom-ffs_352691012497764_LG KG110]...
file saved: backup_XXX-XX V10i ARB KG110P40_eeprom-ffs_352691012497764_LG KG110_LG KG110_20071027-153836.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Done
Finished, time used: 297 sec
Device: LG KG110
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
error: unexpected answer during boot procedure
Boot Fail
error: no any expected answer
Finished, time used: 18 sec
Device: LG KG110
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
error: boot failed: 3B
possible error: Power key released too fast, need to keep Power key pressed during boot procedure.
Boot Fail
Finished, time used: 8 sec
Device: LG KG110
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
Boot Fail
Finished, time used: 19 sec
Device: LG KG110
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
file saved: backup_eeprom_352691012497764_LG KG110_20071027-164722.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Alchemy data
Write Done
Finished, time used: 1106 sec
THIS IS LOG LG KG110 CAN BOOT/FREEZE - FLASHING COMPLETE N PHONE GET ALIVE AGAIN
Old 03-04-2008, 17:20   #3 (permalink)
nomangsm's Avatar
Member: 121662
Thanks Meter: 39
Mate! 1st connect your phone then Flash your phone following file
1- KG110P40-20-V10b_602-03_MAY-31-2007_code
2- KG110P40-20-V10b_602-03_MAY-31-2007_alchemy_Arabic
Then only go to Service option connect your phone again then press Reset settings option your phone live.
need help from samsung experts sartaj Trident/AGERE Platform 0 04-11-2007 07:22
need some help from the expert...!! bawangdagreat Nokia Base Band 5 ( BB-5 ) 0 04-06-2007 15:25
Need Help from 6600 Experts sharaz191 Nokia Hardware & Hardware Repair 6 08-20-2006 17:34
Need help from computer experts!!! Drug_Store Off Topic Zone 11 06-21-2005 16:24
need help from de EXPERT.. johnny_clk Nokia Multimedia 0 04-18-2004 16:39
Page generated in 0.28226 seconds with 8 queries
