07-30-2009, 21:59 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
07-31-2009, 08:04 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | yes phone say english selected im have pin finder but mi box have old cables set how to detected rx and tx manual withaut pinfinder in this phone br. |
07-31-2009, 17:17 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! would be nice if you could send this firmware to us for collecton. [email protected] tahnk you in advance! |
07-31-2009, 21:51 | #6 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | yes sir im send eeprom and full flash readed from phone to us again thanks for support all time success with infinity team im hapy with you............ |
The Following User Says Thank You to delchoni For This Useful Post: |
03-01-2010, 19:38 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! do not waste your time for waiting. take multimeter and find pinout in 5minutes: 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
need help to find pinout for 6500 slider china | fastlink Jogja | Infinity-Box | 1 | 10-18-2009 14:59 |
Please Help to find pinout ! | Unlocker_001 | Infinity-Box | 9 | 10-26-2008 07:59 |
i need help for find pinout | genci titi 2002 | Infinity-Box | 8 | 09-13-2008 15:44 |
Easiest way to find pinout in chinese | Ravvi | Infinity-Box | 8 | 04-19-2008 19:05 |
help to find pinout to k750 | aclgsm1 | Sony Ericsson | 3 | 09-24-2005 08:42 |
