01-06-2016, 15:20 | #1 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Need Help With Flash.... Maybe flashed. Condition when it come to me hang on Samsung Factory Reset will not Help. Phone Info Quote:
On Back Side Says SM N9600 but that model not exist. When Phone Start UP It Says SM - G9600V Then will hang on SAmsung I Open Phone and on PCB was P700 checked for MTK6572 P700 Results are This is mine phone But which flash file to use Thanks in Advance | |
01-06-2016, 16:01 | #2 (permalink) | ||
Member: 322417 Status: Offline Thanks Meter: 940 | I Found some Flash File over internet sm G9006V After Flash phone will turn ON completely but LCD Problem Hear is Flashing Log Quote:
I Have read org flash so i revert it back There is pic with half yellow screen how phone look after flashed with s9006v flash 6572. Uploaded scatter file from flash downloaded This is Scatter file that i read from phone before i flash it Quote:
01-06-2016, 17:22 | #4 (permalink) | ||
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
When i flash with Downloaded flash file S9600V From Internet phone will start up, but screen will be as on image. I had simalar problem with 2 other phones after flash screen driver problem maybe. After flash with saved flash phone will hang on Samsung but with downloaded flash will turn on completely with strange LCD .. I Think this is phone accordint to his PCB Quote: Thank You | ||
01-06-2016, 20:02 | #6 (permalink) | |
There is no uboot.bin in backup folder.There is lk.bin and logo.bin As i Remember the drivers are stored in lk.bin To rename from stuck lk.bin to uboot.bin then copy to folder where phone turns ON with LCD Problem and flash it ? | |
01-07-2016, 07:10 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | LK, right. UBOOT<=>LK. Change that file , and edit cscatter, which you download - it have much useless garbage. Remove protect_f and s, with nvram as well. Just for start. |
01-07-2016, 10:52 | #8 (permalink) | |
So on free time edit - upload and i will try flash again. partition_name: UBOOT leave unchanged i will rename lk.bin Just remove useless commands its take to long to flash. Thank You | |
01-07-2016, 14:13 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | btw - in this FW scat partitioning completely wrong. Seems as read by some very "great" tool. Code: ############################################################################################################ # # General Setting # ############################################################################################################ - general: MTK_PLATFORM_CFG info: - config_version: V1.1.1 platform: MT6572 project: mtk_android storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 ############################################################################################################ # # Layout Setting # ############################################################################################################ - partition_index: SYS0 partition_name: PRELOADER file_name: preloader.bin is_download: true type: SV5_BL_BIN linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0x880000 region: EMMC_BOOT_1 storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BOOTLOADER reserve: 0x00 - partition_index: SYS1 partition_name: MBR file_name: MBR.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x880000 physical_start_addr: 0x880000 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS2 partition_name: EBR1 file_name: EBR1.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x900000 physical_start_addr: 0x900000 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS3 partition_name: PRO_INFO file_name: NONE is_download: false type: NONE linear_start_addr: 0x980000 physical_start_addr: 0x980000 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED reserve: 0x00 - partition_index: SYS4 partition_name: NVRAM file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0xC80000 physical_start_addr: 0xC80000 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BINREGION reserve: 0x00 - partition_index: SYS5 partition_name: PROTECT_F file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x1180000 physical_start_addr: 0x1180000 partition_size: 0xA00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED reserve: 0x00 - partition_index: SYS6 partition_name: PROTECT_S file_name: protect_s.bin is_download: false type: NORMAL_ROM linear_start_addr: 0x1B80000 physical_start_addr: 0x1B80000 partition_size: 0xA00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED reserve: 0x00 - partition_index: SYS7 partition_name: SECCFG file_name: NONE is_download: false type: NONE linear_start_addr: 0x2580000 physical_start_addr: 0x2580000 partition_size: 0x20000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x00 - partition_index: SYS8 partition_name: UBOOT file_name: uboot.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x25A0000 physical_start_addr: 0x25A0000 partition_size: 0x60000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS9 partition_name: BOOTIMG file_name: bootimg.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x2600000 physical_start_addr: 0x2600000 partition_size: 0x600000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS10 partition_name: RECOVERY file_name: recovery.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x2C00000 physical_start_addr: 0x2C00000 partition_size: 0x600000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS11 partition_name: SEC_RO file_name: secro.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x3200000 physical_start_addr: 0x3200000 partition_size: 0x40000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS12 partition_name: MISC file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x3240000 physical_start_addr: 0x3240000 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x00 - partition_index: SYS13 partition_name: LOGO file_name: logo.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x32C0000 physical_start_addr: 0x32C0000 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS14 partition_name: EXPDB file_name: NONE is_download: false type: NONE linear_start_addr: 0x35C0000 physical_start_addr: 0x35C0000 partition_size: 0xA00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x00 - partition_index: SYS15 partition_name: ANDROID file_name: system.bin is_download: true type: EXT4_IMG linear_start_addr: 0x3FC0000 physical_start_addr: 0x3FC0000 partition_size: 0x2B200000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS16 partition_name: CACHE file_name: cache.bin is_download: true type: EXT4_IMG linear_start_addr: 0x2F1C0000 physical_start_addr: 0x2F1C0000 partition_size: 0x17800000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS17 partition_name: USRDATA file_name: userdata.bin is_download: true type: EXT4_IMG linear_start_addr: 0x469C0000 physical_start_addr: 0x469C0000 partition_size: 0x52C00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE reserve: 0x00 - partition_index: SYS18 partition_name: FAT file_name: NONE is_download: false type: NONE linear_start_addr: 0x995C0000 physical_start_addr: 0x995C0000 partition_size: 0x519C0000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE reserve: 0x00 - partition_index: SYS19 partition_name: BMTPOOL file_name: NONE is_download: false type: NONE linear_start_addr: 0xFFFF00A8 physical_start_addr: 0xFFFF00A8 partition_size: 0x1500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: false is_reserved: true operation_type: RESERVED reserve: 0x00 |
01-07-2016, 14:31 | #10 (permalink) | |
So in this case nothing to do with this set? | |
