04-02-2008, 16:12 | #1 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | need help to flash cect u8810 (tv mobile) cect u8810 (tv mobile) when i press power on it start 1%....to 100% and show welcome and resart and restart. i formatted by infinity but same. logs............................ COM7 [VCP0] selected Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 97 sec Remove/Install battery now ! COM7 [VCP0] selected Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 100 sec Remove/Install battery now ! so i flash it by this version"BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_ 7670_HYN_HY128_V2_1__Cect-N528_128m_En_Cn.B4M" logs............... Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.35 S/N: 0D90:010E Wait... Device: Autodetect 6205-6227 NOR Done Device: Autodetect 6228 NAND Loading file v.02... BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M.bin loaded identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424 You have loaded file with security features enabled. detecting languages... Languages: En Cn COM7 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... reading structure area... detecting structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._BXWY 28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN_HY1 28_V2_1.BIN_DBBB7B34_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_ 432_7670_HYN_HY128_V2_1.BIN_DBBB7B34_.rpl warning: unknown identification#1 structure: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? Initialize bootcode Done Check firmware integrity... Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... write core area 1 of 3... write core area 2 of 3... error: code: A500000BF1 error: code: 5AA51C00 error: code: error: block/offset: 000000A2/000A2000 error: can't write nand core Backup required data Fail Finished, time used: 557 sec Remove/Install battery now ! but same........... i don't know which version should use???? now phone is only boot(black screen,not white)until i press power button. PLEASE HELP ME OUT. ALOT OF THANKS |
need help to flash e50 adead nokia e50 ?help pls | abdelnasr56 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-02-2008 14:06 |
NEED HELP to flash 6235 problem are blink auto shutdown stop at flashing content Pac | S E N O P A T I | Nokia CDMA | 2 | 01-01-2008 07:32 |
NEED HELP to flash 6235 problem are blink auto shutdown stop at flashing content Pac | S E N O P A T I | Nokia CDMA | 0 | 11-22-2007 14:21 |
need help to flash my w550i!!! please help! | rockett2k5 | Sony Ericsson | 1 | 06-27-2006 09:13 |
Need help to flash the T39mc | subaru | Old Ericsson Phones & Sony Phones | 0 | 05-24-2003 08:35 |
