04-19-2009, 07:11 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 932308 Status: Offline Thanks Meter: 0 | Need a help to flash orion 910ds |
04-19-2009, 07:35 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
04-19-2009, 08:08 | #3 (permalink) |
Member: 932308 Status: Offline Thanks Meter: 0 | Hi thanks a lot for your steps. But when i am trying to Read information through the infinity i am getting following error. unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! T I have tried using RJ45 cable and USB cable but unable to detect phone form the Infinity software. Can you please help me to detect phone form software |
04-20-2009, 10:14 | #5 (permalink) |
Member: 932308 Status: Offline Thanks Meter: 0 | Hi unable to detect pings from pin-finder. i am getting following error message. software version: 1.17 cable type: 1x8 (L8A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM15... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 27 sec Power Off ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
04-22-2009, 06:52 | #7 (permalink) |
Member: 932308 Status: Offline Thanks Meter: 0 | I have tried to power on phone from box power. But my phone is dead so it doesn’t visible anything have used "cable type: 1x8 (L8A)". But still getting same warning massage. Please help me to sole this issue. Or else tell me how to manually select Rx/Tx pings and power on my phone |
need your help to flash K700i just blink | leroi | FuriouS II | 16 | 02-15-2006 13:07 |
I need some help to flash a Z500 | doctormike | TST Dongle | 2 | 10-04-2005 12:44 |
need some help to flash a dead E1000 | sorinm | Smart-Clip | 2 | 07-25-2005 21:45 |
I need some help to flash Nokia3310.... | Rock | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-06-2003 13:17 |
