01-22-2016, 20:57 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: worldwide
Member: 1948841 Status: Offline Sonork: yocomic Thanks Meter: 45 | need help flashing huawei y330 it may be driver?? Chinese Miracle II [MTK module] v 1.40 Load File File_Info : huawei72_we_jb3 FileVersion : MT6572 Load File Ok Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : Huawei-Y330-U05_HUAWEI72_WE_JB3_HSPA_MOLY.WR8.W1315.MD.WG.MP.V 15.P11_2014-05-14_Claro.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
01-22-2016, 21:34 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-22-2016, 21:52 | #4 (permalink) |
Member: 1948841 Status: Offline Sonork: yocomic Thanks Meter: 45 | Chinese Miracle II [MTK module] v 1.40 Load File Operation : Flash [ v1.40 ] ======= Flash Nothing to flash! Select file first! File_Info : huawei72_we_jb3 FileVersion : MT6572 Load File Ok Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : Huawei-Y330-U05_HUAWEI72_WE_JB3_HSPA_MOLY.WR8.W1315.MD.WG.MP.V 15.P11_2014-05-14_Claro.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! |
01-22-2016, 22:34 | #7 (permalink) |
Member: 1948841 Status: Offline Sonork: yocomic Thanks Meter: 45 | i set to sp on setting and use huawei G610 and this happen Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : Huawei-Y330-U05_HUAWEI72_WE_JB3_HSPA_MOLY.WR8.W1315.MD.WG.MP.V 15.P11_2014-05-14_Claro.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473C66725A8A91F9 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : Huawei ProdName : Y330-U05 ProdModel : HUAWEI Y330-U05 Device : hwY330-U05 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.37 ISPFF ID : 6572 , TARGET ID : 6572 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase disabled Write Flash now ... [ MCU ] : Huawei-Y330-U05_HUAWEI72_WE_JB3_HSPA_MOLY.WR8.W1315.MD.WG.MP.V 15.P11_2014-05-14_Claro.ispff Init Ok , Sending blocks ... for some resaon program stop at 95% |
