12-26-2021, 14:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | need help Infinix_PR652B >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : [DMOBILE]Infinix_PR652B .pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
12-26-2021, 16:45 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You must use the same password as for your IOS web account. How to get Username - https://infinity-box.com/support/?r=22 How to reset forgotten passwordt - https://infinity-box.com/support/?r=16 Check it and try again. What is the result? |
06-25-2022, 12:09 | #3 (permalink) | |
Member: 574410 Status: Offline Thanks Meter: 93 | Quote:
Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: {"Message":"Access denied `9FA32733` product 908 declined or wrong password"} >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! I reset my password but same error | |
06-26-2022, 11:02 | #6 (permalink) | |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Quote:
HI BRO ENTER CORRECT IOS USERNAME AND PASSWORD AND CONNECT YOUR PC ON NETWORK THATS HOW I DD IT Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Infinix : PR652B Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:28 | |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
06-26-2022, 12:03 | #7 (permalink) | |
You must enter good username, see here https://infinity-box.com/service/ | |
06-26-2022, 12:03 | #8 (permalink) | |
