Member: 996444
Thanks Meter: 7 | .:::Need Help Infrinity Team::. GRAN N120 Not Unlock With Infrinity
I Do Sp Unlock Prosess Complet But Phone Show Invalid Sim card
Flash & Format FFs but Same .Plz Infrinity Teem How To Unlock This Phone
Afer Unlock All Cod Open Show Infrinity Box I Put Sim Snd Same Invalid Sim Card....
hare is all log Quote:
COM12 [VCP3] selected
Device: Gtran N120
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6227:8A02:8A01]...
CPU: MT6227
chip: 0031:13C1:CCD6
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN
ver. sw2: MAUI.06A.W06.44.MP.V20, 00000000
ffs offset/size: 00E00000/001E0000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20090422-164337.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
==== log opened: [4/22/2009 4:59:47 PM] ====
Application: C:\Program Files\InfinityBox\MModule\MModule.exe
Loading data, wait...
[Infinity Box] v2.15
S/N: 0F52:0112
Wait...
Device: Gtran N120
Done
Loading file v.02...
GTran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20_158VEDT_2007-05-02_En_Es.B0M.bin loaded
detecting languages...
Languages: En Es He
Languages: En Es He
Device: Gtran N120
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20090422-170208.B0E.bin
Write...
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 104 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
operation aborted
Action: read codes
unlock method: read codes
Model: Gtran N120
19200 autodetect
CPU: MT6227
Connecting, wait...
Phone detected, wait...
Hardware: MT6227,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.06A.W06.44.MP.V20
Version: J2_MAIN_Rev02
42 byte(s) read
imei: 35552200164768
connection Ok
148 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 0000
Finished, time used: 20 sec
Action: unlock
unlock method: smart fast
Model: Gtran N120
19200 autodetect
CPU: MT6227
Connecting, wait...
Date: 2005.04.12
Version: 1.0
42 byte(s) read
connection Ok
148 byte(s) read
reading data...
building new data...
writing data...
done
Finished, time used: 14 sec
Action: imei
Model: Gtran N120
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6227, E02
Hardware version: J2_MAIN_Rev02
Software version: MAUI.06A.W06.44.MP.V
Software date: 2005.04.12
Barcode: AT+EGMR=0,5
imei: 355522001647688
imei write method: mode-1
new imei: 350448011234561
imei verified Ok
Finished, time used: 13 sec
Power off phone now !
Device: Gtran N120
Action: unlock
unlock method: standard fast
Unlock procedure can be faster if you skip eeprom area backup procedure.
Do you want to disable eeprom backup ?
eeprom backup disabled
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
lock area found
detecting additional parameters...
error: additional parameters detection failed
Write...
Write: lock-area-1
Write Done
Finalization...
Finalization Done
Finished, time used: 88 sec
Device: Gtran N120
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN]_20090422-171025.B0E.bin
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 126 sec
| How To Solv This Problim |
