12-08-2014, 12:08 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | KitKat MTK 6582 Q Mobile I10 Read/ Write Flash Done Load File File_Info : lcsh82_wet_hz_kk FileVersion : MT6582 Load File Ok Operation : Flash [ v1.07 ] ======= Flash Files set for flashing : [ MCU ] : MT6582__QMOBILE__QMobile_i10__ALPS.KK1.MP1.V2.11__ Android_4.4.2__20141015_060232.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42015DFCE0677187 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42015DFCE0677187 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : QMobile ProdName : QMobile i10 ProdModel : QMobile i10 Device : QMobile i10 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 ISPFF ID : 6582 TARGET ID : 6582 Flash pre-erase disabled Write Flash now ... [ MCU ] : MT6582__QMOBILE__QMobile_i10__ALPS.KK1.MP1.V2.11__ Android_4.4.2__20141015_060232.ispff Init Ok , Sending blocks ... Write done , 7456 blocks sent Done! Elapsed: 00:24:53 Reconnect Power/Cable! Regard FullFlashPak |
The Following 6 Users Say Thank You to FullFlashPak For This Useful Post: |
12-09-2015, 08:05 | #3 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: DAKAK
Member: 673346 Status: Offline Thanks Meter: 8 | Qmobile I10 Quote:
Bro , where is flash file pls upload here | |
