Old 03-09-2017, 14:09   #1 (permalink)
parth gupta's Avatar
Member: 942210
Sonork: 1511
Thanks Meter: 75
need help micromax D321
Dear infinity team
How to solve this problem
Micromax d321 hang on android logo i flashed the phone same firmware but problem same hang on android logo
Old 03-09-2017, 14:20   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 648
Hello,
Test Emmc R/o maybe ur emmc is in Read only state,,, post logs after test
Old 03-09-2017, 15:08   #3 (permalink)
Member: 942210
Sonork: 1511
Thanks Meter: 75
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040501A2A7A43231
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A2A7A43231
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xE3BC67B82A464EF42F500118532A4186
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3528 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040501A2A7A43231
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:32
Reconnect Power/Cable!
Old 03-09-2017, 15:34   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,022
Hello,
Phone stuck on recovery mode or on logo?
If stuck on recovery mode even after flash check hardware (volume keys etc).
If stuck on logo then erase flash first and flash again.
Remember to flash with same version written on back label.
Br.
Infinity Box Team.
Page generated in 0.22249 seconds with 7 queries
