04-22-2008, 14:28 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Ampah, East Barito -Indonesia Age: 44
Member: 238204 Status: Offline Thanks Meter: 56 | Need Help ! (MicXon S-600) Restart can't format ffs and read eeprom/full flash Code: COM5 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot disabled high speed disabled boot step size: 0400 error: bootcode load error: 4003E1C1200EE0422BE2E081E003E002E004E18E402CE59DE004E08EC00CE0 8EE764E59F4001E1C2C00EE08CC96CE082E001E00CE004E18E4000E59DE004 E08E3003E08EE744E59F4002E1CC300EE0833663E08CE002E003E004E18E40 14E59DE004E08E1001E08EE724E59F400CE1C3100EE0411DE1E083E00CE001 E004E18E4028E59DE004E08E2002E08EE704E59F4003E1C1200EE0822BE2E08 1E003E002E004E18E403CE59DE004E08EC00CE08EE6E4E59F4001E1C2C00EE 04CC96CE082E001E00CE004E18E4010E59DE004E08E3003E08EE6C4E59F400 2E1CC300EE0433663E08CE002E003E004E18E4024E59DE004E08E1001E08EE 6A4E59F400CE1C3100EE0811DE1E083E00CE001E004E18E4038E59DE004E08 E2002E08EE684E59F4003E1C1200EE0822BE2E081E003E002E004E18E400CE5 9DE004E08EC00CE08EE664E59F4001E1C2C00EE04CC96CE082E001E00CE004 E18E4020E59DE004E08E3003E08EE644E59F4002E1CC300EE0833663E08CE0 02E003E004E18E4034E59DE004E08E1001E08EE624E59F400CE1C3100EE041 1DE1E083E00CE001E004E18E4008E59DE004E08E2002E08EE604E59F4003E1 C1200EE082FF00 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 15 sec Remove/Install battery now ! |
04-23-2008, 07:18 | #5 (permalink) |
Member: 238204 Status: Offline Thanks Meter: 56 | Problem resolve ! :D Serching pinout mcu_b Code: software version: 1.07 cable type: 2x6 (L12B) platform: MT6205, MT6217-MT6228 searching adapter at COM5... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:4 Tx:2 time required: 14 sec Power On ! Code: software version: 1.07 cable type: 2x6 (L12B) platform: MT6205, MT6217-MT6228 searching adapter at COM5... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:5 Tx:3 time required: 14 sec Power On ! Code: COM5 selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CAC1:3442 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: MAUI.05C.W06.16 Version: MALATA26_05C_HW detecting structure #2... done 60 byte(s) read imei: 35888356011039 connection Ok building list... done items to clear: 200 warning: wrong packet cs warning: wrong packet cs 199 of 200 items cleared building list... done 1 items remains Finished, time used: 46 sec Remove/Install battery now ! infinity still the best for Chinese Miracle.... Br. AMIEN |
i need pinout for MICXON S-600 | wahyu_smd | Infinity-Box | 8 | 02-14-2010 18:04 |
need help samsung e250 old restart on cam | jericho28 | Samsung Hardware Repair | 2 | 08-28-2009 00:15 |
Need Micxon E-600 | wong java | CPF-BOX Ⅱ | 2 | 06-24-2009 04:19 |
need micxon S-600 flash file | ck_bungas | SpiderMan | 2 | 09-11-2008 05:15 |
need help on treo 600 | Softway | PalmOS /HP and others | 5 | 06-19-2008 03:01 |
