Old 04-12-2008, 12:25   #1 (permalink)
korter's Avatar
Member: 171307
Thanks Meter: 138
Need help with N203 2nd CPU
HI. Have Chineese N203 phone. Always Slave Initialing for 2nd sim. HOw can we repair this phone. I am trrying to format 2nd Cpu with RXB and TXB but it gives errors
COM2 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection disabled
Action: reset
enhanced security fix enabled
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot disabled
high speed disabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: BF7353FFFF0052:FFFFFF00000000
flash: SST SST34HF3244/3284 U 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00380000
checking area[00000000]: 00000000-003FFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00380000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00080000
ffs chip: 00
eeprom/ffs area: 00000000:00380000-003FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 52 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-12-2008, 14:06   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
looks like you second MCU flash is completely erased or chip is damaged
you must try flash your second phone flash with proper flash file
Old 04-12-2008, 14:48   #3 (permalink)
korter's Avatar
Member: 171307
Thanks Meter: 138
where to find proper flash file?
When read General Info it shows
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: MALATA26_05C_HW
Software version: MAUI.05C.W06.16"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
Old 04-12-2008, 17:10   #4 (permalink)
Member: 148515
hello!
somehow we must get know second MCU software version.
can you find same working phone on local market to read out flash?
Old 04-12-2008, 17:17   #5 (permalink)
korter's Avatar
Member: 171307
Thanks Meter: 138
Already repaired with flashing this file.
CM_Sands-A303i-CPU2_MAUI.05B.W06.04_MALATA05_05B_MTK05_05B_8988_4 m_En_w_eeprom.B0M
Thanks
Old 04-14-2008, 08:20   #6 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 304
korter very very very thanks .. my sands a303 Slave Initializing problem solved , after this file add write
need help with n99+ spiderman spreadtrum cpu n-box SpiderMan 7 09-07-2009 20:09
i need help with my d600e, i need SUS software, PLZ HELP ME I AM BEGGING YOU *agent47* SWIFT Platform 1 07-23-2006 20:03
(writing a faq need help) Confused, need help with uploading pictures. Vis Major X Motorola P2k 6 04-06-2004 09:49
Help with Dejan&P4_1.8Ghz CPU SaryK Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 02-23-2003 19:42
need help with sony cd5 locked with d2 germany Teracite Various 1 05-27-2000 01:31
Page generated in 0.32356 seconds with 8 queries
