06-08-2015, 09:11 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: inside the box Age: 40
Member: 765233 Status: Offline Sonork: 100.1664273 Thanks Meter: 107 | need help not supported flash type Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
06-08-2015, 09:37 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, First Of All Click On "Identify" In Service Tab. If Read Info Complete Then You Can "Read Full" Flash File Not Factory Firmware. If Read Info Show This Error : Not supported FlashType for this operation yet So Now Try With These Mode One By One. Click On Setting -> SP : Other -> NAND Init Mode -> P1, P2, P3, P4 ExBoot. Post Result Please. |
06-08-2015, 10:01 | #3 (permalink) | |
Member: 765233 Status: Offline Sonork: 100.1664273 Thanks Meter: 107 | Quote:
06-08-2015, 13:41 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | When it will work enough safe and stable, as we made with MTK eMMC phones. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
