Old 06-28-2007, 07:01   #1 (permalink)
gokul2005's Avatar
Member: 169384
need help for panasonic vs3
i flash the panasonic VS3. after flash set power on ok but noletters in display. wn press any numbers only block sqr dots . wt can i do sir.......
Current model: VS2,VS3
Loading file v.01...
VS2_VS3_VF10_Main.2CM.bin Loaded
VS3_FFS1_AMB_r004_d06.2CF.bin Loaded
Testing COM3 at 115200...
Device: VS2,VS3
Checking data, wait...
Action: Flash write
Boot...
Press Power button now !
Checking...
Boot answer: 02
Boot Done
Set Baud...
Set Baud Done
Connecting...
FLASH ID: 0089:880D
Connecting Done
Check free space...
Flash chip supported
In progress [eeprom-01]...
file saved: Backup_eeprom-01_2007-6-16_12-30-20.2CE.bin
In progress [eeprom-02]...
file saved: Backup_eeprom-02_2007-6-16_12-30-21.2CE.bin
Check free space Done
Write...
Reset...
Done
Writing: Firmware
Verifying...
Done
Writing: FFS-1/Customization
Verifying...
Verify result: 0000
Err: probably zone write failed
Write Done
Finished
Remove/Install battery now !
Time used: 1751 sec
Old 06-28-2007, 10:47   #2 (permalink)
Member: 148515
hello!
i think this is a mismatch of Main software and language pack versions.
please flash all parts together and make sure that files are correspondent toeach other
Old 07-04-2007, 11:48   #3 (permalink)
gokul2005's Avatar
Member: 169384
hello!
pls say how to download the same version files......
Old 07-04-2007, 11:54   #4 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
same version means that main file and language files should have same version
best of luck
Best Regards
GSMCrazy1
Old 07-05-2007, 00:23   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
C:\Program Files\InfinityBox\Documentation\Infinity-Box_FlashFilesDescription.htm
Compatible Battery for Panasonic VS3 Phone IPMART ipmart WebShop 0 10-06-2008 08:00
Need help on Panasonic EB-TX210 NAM Programming aZyWeRks Various CDMA/TDMA Cell Phones 6 02-04-2007 09:12
Need help for Panasonic GD75!!! MicrostarGSM® Panasonic 0 06-05-2004 14:35
Need LCD for Panasonic GD-67 NSerN Wanted Products 2 04-19-2003 20:29
Need Pinout For Panasonic Gd35 Flasher katagsm Panasonic 1 03-06-2002 01:35
Page generated in 0.66190 seconds with 11 queries
