Old 10-22-2008, 09:52   #1 (permalink)
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Thanks Meter: 93
need help with phone code
i have this phone model A1308 asking for security code i tried formating and unlocking , also user code function but no hope can somebody help here is log:-
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "user code"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:5D03:0005
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN
ver. sw2: HSD_V001.C18.GB, 00000000
ffs offset/size: 00E00000/00200000
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN]_20081022-094343.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 351 sec
Remove/Install battery now !
Old 10-22-2008, 09:55   #2 (permalink)
eswar7983's Avatar
Member: 702331
Thanks Meter: 61
try this 1122,1234,2244
Old 10-22-2008, 11:06   #3 (permalink)
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Thanks Meter: 93
hi
i tried all default codes not work
Old 10-22-2008, 11:16   #4 (permalink)
eswar7983's Avatar
Member: 702331
Thanks Meter: 61
make ffs format with infinity
Old 10-22-2008, 12:24   #5 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
COM10 selected
module v2.64
Action: read codes
unlock method: read codes
Model: Autodetect 6228, 6229, 6230 NAND
19200 autodetect
Initializing[6228:8A02:8A02]...
CPU: MT6228
high speed boot disabled
chip: 0031:0000:9801
Connecting, wait...
Phone detected, wait...
Hardware: MT6228,E02
Date: 2004.07.02
Version: 1.0
Version: 073245_411_V1350
Version: TIANYU28_06A_HW
detecting structure #2...
0 done
42 byte(s) read
imei: 35355401530841
connection Ok
detecting structure #1...
0 done
148 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 110582
Finished, time used: 31 sec
Remove/Install battery now !,Action: read codes,unlock method: read codes,please try bro
The Following User Says Thank You to PRIMACELL For This Useful Post:
Need help remove phone code from htc touch [ANSWERED & SOLVED] keeran Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 7 01-29-2010 02:37
i need help with radio code plz help roadrunner007 CAR Electronics 1 04-09-2009 11:07
k300 help with phone code alison0101 Sony Ericsson 1 08-15-2005 21:22
Need help with VB code for keymaker in Armadillo Surej GSM Programming & Reverse Engineering 4 02-25-2003 06:01
help with phone code for T190 cris Motorola ODM 1 11-26-2002 11:08
Page generated in 0.35470 seconds with 8 queries
