need help pinout for my 6300 china 1 Attachment(s) help me to find pinout (rx,tx,gnd) for myphone 6300 china. thanks |
in vepro and in spiderman i encounter most of the time 11=TX and 12=RX you know where to put the ground right? try it and post result hope it could help |
1 Attachment(s) Quote:
hello! if not work - try to swap tx/rx wires |
STILL NOT WORK, i am frustration for this. my question : if i buy tx/rx finder box from infinity,what certain solve my problem? |
hello! our auto finding pinout box do not have connector for this test point groupe. if you solder wire to each test point and connect wires to our box- it will find needed pins. but i can advice you another way: measure voltage on each test point pin and then reffer to this tutorial: http:///vbb/attach...7&d=1187384324 this is easy way to find needed pins by high voltage on them. the only problem in oyur case: is to connect battery to power terminals. maybe you must solder wires to "+" & "-" battery terminals and other side to PCB |
1 Attachment(s) Rx and Tx pinouts are perfect but Gnd is change. by the way thank you inifinity for this. happy to use infinity box. |
thanks it's work great........... |
good effert. working . . . . . . . . .. . . . . . . . . . . |
gooood work bro .... nice work |
