Old 02-10-2008, 12:25   #1 (permalink)
not2link's Avatar
Member: 142211
Thanks Meter: 90
need help pinout for my 6300 china
help me to find pinout (rx,tx,gnd) for myphone 6300 china. thanks
Old 02-10-2008, 13:54   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
check this archive, your PCB is there
http://rapidshare.com/files/89821743...00_pinouts.rar
Old 02-10-2008, 14:00   #3 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 632
in vepro and in spiderman i encounter most of the time 11=TX and 12=RX
you know where to put the ground right?
try it
and post result hope it could help
Old 02-11-2008, 10:05   #4 (permalink)
not2link's Avatar
Member: 142211
Thanks Meter: 90
hello!
thank for your respect for myproblem, im found myphone PCB. but sorry, what pinout you give is right?. because still not yet connect.
Old 02-11-2008, 21:41   #5 (permalink)
Member: 148515
hello!
if not work - try to swap tx/rx wires
Old 02-12-2008, 13:49   #6 (permalink)
not2link's Avatar
Member: 142211
Thanks Meter: 90
hello!
hello juga!
STILL NOT WORK, i am frustration for this.
my question : if i buy tx/rx finder box from infinity,what certain solve my problem?
Old 02-12-2008, 21:52   #7 (permalink)
Member: 148515
hello!
our auto finding pinout box do not have connector for this test point groupe.
if you solder wire to each test point and connect wires to our box- it will find needed pins.
but i can advice you another way:
measure voltage on each test point pin and then reffer to this tutorial:
http:///vbb/attach...7&d=1187384324
this is easy way to find needed pins by high voltage on them.
the only problem in oyur case: is to connect battery to power terminals.
maybe you must solder wires to "+" & "-" battery terminals and other side to PCB
Old 02-13-2008, 16:49   #8 (permalink)
Member: 139020
Thanks Meter: 15
Smile
Rx and Tx pinouts are perfect but Gnd is change. by the way thank you inifinity for this.
happy to use infinity box.
Old 04-07-2008, 08:19   #9 (permalink)
bowram's Avatar
Member: 502666
Sonork: 100.1590924
Thanks Meter: 39
thanks it's work great...........
Old 07-15-2008, 21:41   #10 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
good effert. working . . . . . . . . .. . . . . . . . . . .
Old 02-27-2009, 17:17   #11 (permalink)
mazentel..'s Avatar
Member: 155719
Thanks Meter: 93
gooood work bro .... nice work
Need HELP plz for my route 66 chicago PND madtext Nokia Multimedia 1 03-14-2016 16:00
need help to find pinout for 6500 slider china fastlink Jogja Infinity-Box 1 10-18-2009 14:59
**HELP**I need flash file for my china phone..attached pictuer joy4u Chinese Models & Cloned Phones 1 04-20-2009 05:38
i need help please for my L6i chronic Motorola Hardware Repair 0 07-05-2007 20:26
need pinout for my-c2 charger gorgans ARM9 BASED M62 / M62+ 2 04-30-2004 11:46
Page generated in 0.20199 seconds with 10 queries
