10-23-2018, 11:20 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Multan Pakistan Age: 49
Member: 872681 Status: Offline Sonork: 1680923 Thanks Meter: 52 | Need Help for Qmobile S15 frp CM2 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 374 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 374 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : 00200000 Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! |
10-23-2018, 12:47 | #2 (permalink) |
Member: 872681 Status: Offline Sonork: 1680923 Thanks Meter: 52 | Card found : S/N : D1A39347 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 374 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 374 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00200000 Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
10-24-2018, 15:19 | #4 (permalink) |
Member: 872681 Status: Offline Sonork: 1680923 Thanks Meter: 52 | After all i find the error salutation my self. this Qmobile S15 need to connect with both keys pressed vol - and vol + thats all thanks Cyber GSM |
The Following 3 Users Say Thank You to skynumber For This Useful Post: |
11-11-2018, 13:37 | #5 (permalink) | |
Junior Member Join Date: Aug 2017
Member: 2747847 Status: Offline Thanks Meter: 0 | Quote:
Hello Sir. I am trying to unlock my qmobile s15. but am getting rejected in fastboot even though i have enabled oem unlock in developer settings. do you have any idea why it is happening | |
11-11-2018, 14:28 | #6 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
07-21-2019, 08:30 | #7 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Quote:
Working to me Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42314518C80742410105C4 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0xC0000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D4207C818C4057341 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB582A66193CDEB53267E7B3332E89AC9 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! BR | |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
