05-04-2017, 13:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 409 | Need help read file MBI R6 MT 6735 Boot Error! Thank 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00200000 Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
05-05-2017, 05:11 | #2 (permalink) |
Junior Member Join Date: May 2017
Member: 2712637 Status: Offline Thanks Meter: 0 | Read file MEIZU M2 error,please help. Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
05-05-2017, 10:28 | #3 (permalink) | ||
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
SIGNED with SPRELOADER You can try to connect by holding both volume keys but most probably result will be same,Not supported! Quote:
Meizu not supported!! Br. Infinity Box Team. | ||
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
