Need help read info or file oppo f1s Need help read info oppo f1s thank 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! ************************************************** ******** Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 0000 BB_CPU_HW : 0000 BB_CPU_SW : 0000 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! THANK |
Hello, Plz select Second boot Sp boot then connect |
read file Boot Error! Need help 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! |
Try holding volume up (or down) button, and retry operation, if still the same - no solution at this moment. Wait for next update. b.r. Alex |
f1s have 2 hw different but fileflash issame 1 can edentify cm2, 1 secure |
i think mtk updated will release end of activation 1 year support maybe different |
oppo f1s now have 4gb ram with 64 rom. others model and brand (china) mtk base have secure boot , new loader, every month launch . like huawei, oppo, xiaomi. problema that team never update tract current base solution. cause wide range work for that solution. like coding , testing , fixing bugs, lot of works. when team launch update for solution , may come new issue. it's the story. i think all of chines tools is best tools CM2. about that cause infinity team, must care for new update currently demand to his users. on their best level. thanks and best regards, KK |
Alrdy team answer u alot of times dont spam again |
Team is working on wait until release new update |
