10-02-2009, 13:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: MKD Age: 40
Member: 939467 Status: Offline Thanks Meter: 50 | cant use infinity pin finder I ve trying to use infinity pin finder for 2 years but i havent been succesfull.. for example i`m selecting the pinout that is offered for ifoe 168+ from the list I always get this log: COM6 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! I get this all the time with any pinout.. How can i resolve this problem? Regards, |
10-02-2009, 13:41 | #2 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | what power u r using battery ot or pinfinder use pinfinder power supply not battery |
The Following User Says Thank You to maximas007 For This Useful Post: |
10-02-2009, 14:37 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, To avoid 2 years delay I suggest you to check manual before use any kind of devices. PinFinder manual available at your HDD during 2 years already: C:\Program Files\InfinityBox\Documentation\PinFinder but I think it will be better to give you a link. Please, download PinFinder manual: http://www.infinity-box.com/download..._PinFinder.pdf You can see step-by-step instruction with pictures and more than detailed explanation how to use PinFinder. Good luck ! |
how to use infinity pin finder........ | unlock & flash | Infinity-Box | 11 | 02-03-2011 20:27 |
can spiderman used instead of infinity pin finder for infinity box | sajin6660 | Infinity-Box | 8 | 03-14-2010 09:18 |
infinity pin finder can't detect spredtrum cpu pin out perfectly | md.giousuddinso | Infinity-Box | 6 | 10-05-2009 19:08 |
can find bleu 245x pin out using infinity pin finder. | sinikrishna | Infinity-Box | 1 | 01-08-2009 12:59 |
Infinity Pin Finder Want Update | sunnyarora | Infinity-Box | 1 | 03-21-2008 10:33 |
