06-11-2008, 15:01 | #1 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Ukraine Age: 44
Member: 7575 Status: Offline Thanks Meter: 12 | Need help from supporter Here is flash file and backup of system log that program create. Is it possible repair phone by flashing backup of system log of that phone? http://rapidshare.com/files/12168431...135754.B0.html |
07-02-2008, 15:06 | #5 (permalink) | |
Member: 7575 Status: Offline Thanks Meter: 12 | Quote:
Here is log of repair operation seems all is ok, but phone is not power-up COM5 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:0A2F:208F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 761A7DDB identification#1 protocol ver: 04 ver. sw1: E551_C7ARVBT_E551_GPRS_MT6226_S01.01_1.BIN ver. sw2: E551_C7ARVBT.01.1, CB9CD542 ffs offset/size: 00800000/001FF000 flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: security area#1 security area#1 fixed detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done Finished, time used: 63 sec Remove/Install battery now ! | |
07-02-2008, 15:19 | #6 (permalink) | |
COM5 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:0A2F:208F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 761A7DDB identification#1 protocol ver: 04 ver. sw1: E551_C7ARVBT_E551_GPRS_MT6226_S01.01_1.BIN ver. sw2: E551_C7ARVBT.01.1, CB9CD542 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 61 sec Remove/Install battery now ! | |
07-02-2008, 19:04 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As I can see software know this firmware and firmware security area repair. Are you sure that you have used firmaware that completely suitable for your phone ? Even if phones looks very similar it may be that phones has hardware difference. Also are you sure that phone hardware is good ? |
07-03-2008, 08:40 | #8 (permalink) | |
The phone works before flash. If I write fullflash with checked "smart write" (for example to change language) the phone works ok. But If I uncheck "smart write" then phone can't power up after flash. Support of this firmware was made by your team after I have send to your mail fullflsh without the second file called "system log"... P.S. Fullflash and system log that attached to this thread are made after the phone been flashed and can't power on. Is it right or I must send system log of working one? | |
07-03-2008, 09:23 | #9 (permalink) | |
07-03-2008, 11:31 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Even 2 "absolutely the same" chinese models may have big difference inside. So if you have bought 300 phones at once this means that you have bought "300 phones" but this is NOT means that you have bought "300 the same phones". What to do with your phone: you must find firmware that will be suitable for your phone To make phone supported it is need to send ORIGINAL files from GOOD WORKING PHONE, but not from phone that was flashed with other files. |
07-03-2008, 12:27 | #11 (permalink) |
Member: 7575 Status: Offline Thanks Meter: 12 | ok, next step But, If I flash "CM_2GSM_E551_C8V2_E551_GPRS_MT6226_S01.01_0_1 6m_E n_Cn_Cn.B0M" to any my died or working phone, phones power up. If I flash lets say "original" firmware of one of them to other this phone don't power up. I attached flash and system log from original working powering phone. http://rapidshare.com/files/126766417/e551.rar.html - the phone power on So, I think that repair don't work correct for this firmware. |
07-03-2008, 16:04 | #12 (permalink) |
Member: 7575 Status: Offline Thanks Meter: 12 | I fogote to say that if I flash original backup file from the phone to this phone with checked "fix security during flash" the phone do not power up anymore. But if this option unchecked all is ok- phone power on. But If I do "Repair security" on working phone, software do not kill it, the phone continue working... |
need help from support team... | ticksjarub | Motorola P2k | 2 | 09-09-2008 08:04 |
Need help from supporter | NiceLys | Easy-Unlocker | 4 | 08-21-2008 00:20 |
need help from supporter | gsm_eye | DreamBox | 1 | 04-05-2008 20:02 |
smart clip dead !Need help from support | Gsmtechno | Smart-Clip | 3 | 07-16-2007 10:13 |
smart clip dead !Need help from support | Gsmtechno | Smart-Clip | 3 | 07-16-2007 10:11 |
