Unlock Server
Old 02-27-2009, 15:37   #1 (permalink)
hussainafridi's Avatar
Member: 668816
Exclamation need help trend t101
hello i have trend t101 phone code i try to sp unlock but still lock then i download file from support area and try to flash . when flash then give error in erase 70% now set is dead need help.
COM8 [VCP1] selected
module v1.63
Device: Trend-T101
Checking data, wait...
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00BF:7353
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
error: write failed[00400000]
Write Failed
Finished, time used: 400 sec
Remove/Install battery now !
Old 02-28-2009, 13:43   #2 (permalink)
Member: 668816
Needed help.---------
Old 02-28-2009, 18:04   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Try to select BSNL-200 model and flash phone again.
Old 03-02-2009, 07:49   #4 (permalink)
Member: 668816
mobile erasing and flashing complet by this meted, but mobile same problem. mean not on .
i have flashed by this flash file.
1 . Trend-T101_ULC2_Apr-18-2008[1].B1M.bin
2. Trend-T101_2007-Nov-12[1].B1M.bin
but mobile dead like before.
Old 03-02-2009, 07:55   #5 (permalink)
Member: 130995
Hello,
Do you have original full flash backup ?
If phone can not power-on after flash it may be that your phone has different hardware type than other phones, need to use another firmware.
Old 03-02-2009, 08:58   #6 (permalink)
Member: 668816
i have not its orgnel beckup.
then what i do it........
Old 03-02-2009, 13:37   #7 (permalink)
Member: 130995
Hello,
1. you can try to flash your phone with Sky-SK1 firmware, but I can not give you any warranty that phone will be alive
2. If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to mt62xx@gmail.com so we will be able to prepare and upload
good working files in support area for all users.
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
Old 03-03-2009, 05:42   #8 (permalink)
Member: 668816
Great thanks for ur great Answer.
trend t101 eeprom file need gul_hassan528 Infinity-Box 2 08-18-2009 19:50
Need Trend T101 Chinese Pinouts sairat Chinese Miracle & PinFinder 9 12-13-2008 19:33
01 Jun 2008: "Pana01" v1.48:.LG-KG90N, J-Max-J-Diamond, Avvio-103A, Trend-T101, ..... zinoubinabil Infinity-Box 30 06-16-2008 17:33
Cable Trend-T101, Mobility-NR1, Maximus-MX100 Paki Mobile Infinity-Box 7 06-02-2008 17:52
01 Jun 2008: "Pana01" v1.48:.LG-KG90N, J-Max-J-Diamond, Avvio-103A, Trend-T101, ..... Infinity-Box GSM News & Updates 0 06-02-2008 12:16
Page generated in 0.84844 seconds with 11 queries
