03-05-2016, 05:37 | #1 (permalink) |
Crazy Poster Join Date: Aug 2007 Location: Earth Core
Member: 566499 Status: Offline Sonork: 100.1590195 Thanks Meter: 17 | [need help] try not hold volume(+/-) keys on connect! Code: Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B4A5330304D03BE062083C01F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED [WARNING] : eMMC_VALIDATE_FAILED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! trying to not hold vol keys but same error happend anybody out there can help solve those issue?? thanks fyi: both phone are normal works 100% fones, just trying to read info and fig those errors. |
03-05-2016, 06:54 | #3 (permalink) | |
Member: 566499 Status: Offline Sonork: 100.1590195 Thanks Meter: 17 | Quote:
Thanks for reply Brother.., same cable already I use on MT6571, 72, 77, 89, MT6795, SPD, and so; are definitely works fine no error at all, but if use in MT6582 and MT6592 (for present I try) the error would persist like I describe, full batteries I always use, also latest version of CM2 (v1.42) I use but the error still there | |
03-25-2016, 02:00 | #5 (permalink) |
Junior Member Join Date: Dec 2008
Member: 915660 Status: Offline Thanks Meter: 0 | please don't judge as if it only happened on both MT6582 and MT6592. coz i just got the same problem. I tried same type of MT6572, same cable at the same time, but different phone, OPPO and ADVAN. here is the result.. Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344739301096CFC3573121 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 1101003030344739301096CFC3573121 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 6997F3561A286565D3F66BBE87A4F10D INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! (OPPO R2001) Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 0600003136FFFFFFFFFF195C493934EB [WARNING] : eMMC_VALIDATE_FAILED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! (ADVAN S4A) any solution? it might be a hardware issue.. |
03-25-2016, 09:12 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
What is condition of Advan phone? Try connecting without pressing any keys. Br. Infinity Box Support Team. | |
03-26-2016, 17:19 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | eMMC Flash : 0600003136FFFFFFFFFF195C493934EB [WARNING] : eMMC_VALIDATE_FAILED This one seems as dead. |
04-10-2016, 09:26 | #8 (permalink) |
Freak Poster Join Date: Aug 2010 Location: next to obama
Member: 1370494 Status: Offline Sonork: dont have Thanks Meter: 35 | thank you its working without presing any kays not giving error |
The Following User Says Thank You to ..::HaCkEr::.. For This Useful Post: |
11-19-2016, 19:22 | #9 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | I have a problem with MT6580, I can not do anything on the device, it is not dead. Wait for phone... Phone found! [ 133 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642026AB63024133C7 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
12-27-2016, 14:29 | #10 (permalink) |
Crazy Poster Join Date: Sep 2004 Location: Ukraine, Lugansk Age: 44
Member: 81462 Status: Offline Thanks Meter: 4 | Hello, phone is Ark benefit with code. I dont unblock this phone( 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 70010053313030303408277CDF3143B3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following User Says Thank You to Andressota For This Useful Post: |
12-27-2016, 15:26 | #11 (permalink) | |||
Freak Poster Join Date: Sep 2009 Location: In Your Sweet Heart
Member: 1124357 Status: Offline Thanks Meter: 70 | Dear Friends Quote:
I Also Face This Type Problem, Not Connecting My Handset Then I Tried In Windows XP,My Problem Solved. CM2`s Qualcomm Not Working In My Window 7 32bit Br, Anil Sharma | |||
02-23-2017, 09:20 | #12 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 70010045453445413401088EFD7963F1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! inferno key id not found |
03-27-2017, 17:26 | #13 (permalink) |
Insane Poster Join Date: Nov 2009 Location: Cox's Bazar Age: 38
Member: 1166990 Status: Offline Thanks Meter: 7 | Symphony w21 IMIE write problem plz help [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! |
