12-27-2017, 07:03 | #16 (permalink) |
Insane Poster Join Date: Jul 2017 Location: Bangladesh Age: 29
Member: 2740295 Status: Offline Thanks Meter: 33 | Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 700100454534454434010BB3310384F7 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Help plzz... |
06-22-2018, 06:49 | #19 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2748337 Status: Offline Thanks Meter: 1 | same problem on flare s5 plus status before hang on logo after format cm2 dongle now status is dead chipset on this phone MT6753 [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following User Says Thank You to biverclint1223 For This Useful Post: |
10-02-2018, 12:08 | #21 (permalink) | |
Insane Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 867112 Status: Offline Thanks Meter: 41 | Quote:
only use usb cabel////dont use bateery or poewr supply,,,,,only flash by usb cabel | |
10-04-2018, 07:12 | #22 (permalink) | |
Major Poster Join Date: Jul 2009 Location: lagos nigeria
Member: 1086857 Status: Offline Sonork: gsmhiprest Thanks Meter: 2 | Quote:
12-19-2019, 07:08 | #24 (permalink) |
Registered User Join Date: Dec 2014 Location: dhaka
Member: 2309778 Status: Offline Thanks Meter: 3 | Card found : S/N : A5E3200E , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D42012962A88764C5 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:13 |
04-27-2021, 04:48 | #25 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | @usman143skt this is Infinity Section not for any other product/tool please do not spam here |
The Following User Says Thank You to kamal_singla For This Useful Post: |
05-03-2021, 16:00 | #27 (permalink) |
Freak Poster Join Date: Sep 2015 Location: GHANA WEST AFRICA
Member: 2460709 Status: Offline Thanks Meter: 25 | same problem with me too, when trying to remove frp on infinix x 650 but cant connect Card found : 0860A5B3 , v0148 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.22 Load IDBase v428174 Ok! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-03-2021, 16:02 | #28 (permalink) |
Member: 2460709 Status: Offline Thanks Meter: 25 | Card found : 0860A5B3 , v0148 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.22 Load IDBase v428174 Ok! Operation : Identify [ v2.22 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-04-2021, 10:35 | #29 (permalink) | |
Install v2.21 and try to connect with it. Result? | |
