01-18-2010, 14:12 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 279 | zte gx 761 dead while flashing |
01-18-2010, 14:52 | #4 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
This phone can not be killed permanently, you can repair this kind of phones with Infinity-Box even in case of empty-board phone. You need to double check battery voltage and flash phone with latest firmware from support area. Also you can check what was original phone firmware version (see operation.log file in folder with module) and flash phone with the same firmware that was in phone before. | |
01-18-2010, 14:52 | #5 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 279 | here is the log of flashing my phone module v3.01 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_03[1].X761_Z0_S_AFFA106.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN_020FBE36].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN project-id: X761_Z2_SF_BFFA103, 36BE0F02 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs_20100118-191738.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100118-191939.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 01227E22312200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100118-192021.B0X.bin Finished, time used: 5 min 10 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-18-2010, 14:59 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, This phone can not be killed permanently, you can repair this kind of phones with Infinity-Box even in case of empty-board phone. You need to double check battery voltage and flash phone with latest firmware from support area. Also you can check what was original phone firmware version (see operation.log file in folder with module) and flash phone with the same firmware that was in phone before. |
01-18-2010, 15:24 | #7 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 279 | i wants to know wats the reason of flashing to fast in the start meens to say why it write to fast in the start to 95% i thinks flashing is not storing in flash or any other reason becoz i face thsi problem in many chinese handset while flashing but my problem solved after changing the file but here nothing happen |
01-18-2010, 16:41 | #8 (permalink) | |
Member: 271008 Status: Offline Thanks Meter: 279 | flash with same file but my handset still dead Quote:
module v3.01 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash "format ffs" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_04[1].X761_Z2_SF_BFFA108.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN_020FBE36].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN project-id: X761_Z2_SF_BFFA103, 36BE0F02 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs_20100118-205412.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100118-205447.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 01227E22312200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100118-210743.B0X.bin Finished, time used: 15 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
01-18-2010, 17:45 | #9 (permalink) | |
Flash phone again, but make "format ffs" box UN-checked | |
01-18-2010, 17:52 | #10 (permalink) | |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Quote:
i had uk t-mobile x760 with me ,i unlock it with other tool coz infinity said unknown version,so phone was unlock with other tool,but no network,so desided to flash with eprom file.and phone goes dead.then i flash with t-mobile crotia file,but same its not turning on. and i guess there is no t-mobile uk flash file in support,can u plz tell me which file i need to use for flashing ,shall i flash eprom part too,and which eprom i need to flash as well.thnx for your great support | |
01-18-2010, 17:56 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10HR_ GH_BFFA105_Vairy-Touch_En_Hr_De.B0M.bin ZTE-X760_ffs_06.X760_Z10HR_GH_BFFA105.B0E.bin "format ffs" box UN-checked during flash write. |
01-19-2010, 07:12 | #12 (permalink) | |
Member: 271008 Status: Offline Thanks Meter: 279 | still dead what to do? Quote:
module v3.01 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA103_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_04[1].X761_Z2_SF_BFFA108.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN_020FBE36].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 03.BIN project-id: X761_Z2_SF_BFFA103, 36BE0F02 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__ffs_20100119-112305.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100119-112312.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA103__system_log_4B358AE5_020FBE36_20100119-113547.B0X.bin Finished, time used: 15 min 19 sec Remove/Install battery now ! | |
01-19-2010, 08:36 | #13 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 279 | problem solved with this flash file COM3 [VCP0] selected module v3.01 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA106_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ZTE-X761_ffs_03[1].X761_Z0_S_AFFA106.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22312200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4B358 AE5.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_BFFA1 04.BIN_2855C759].rpl rom info detection finished device-id: 4B358AE5 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_BFFA1 04.BIN project-id: X761_Z3_Pt_BFFA104, 59C75528 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_ BFFA104__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_ BFFA104__ffs_20100119-124323.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_ BFFA104__system_log_4B358AE5_2855C759_20100119-124337.B0X.bin Area: Firmware flash: 01227E22312200:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22312200:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z3_PT_ BFFA104__system_log_4B358AE5_2855C759_20100119-125524.B0X.bin Finished, time used: 14 min 26 sec Remove/Install battery now ! |
01-20-2010, 01:04 | #14 (permalink) |
Member: 272137 Status: Offline Thanks Meter: 75 | phone is get life now,after u told me flash file for flashing , but after flash phone got signal for some seconds first time,after flash.now every time no service,wat u suggest me.thnks in advance for your persnol attention,great infinity support |
01-21-2010, 22:35 | #15 (permalink) | |
Check phone imei (*#06#) and repair it if need. Try to make 112/emergency call without sim card. What is the results ? It may be that phone has a hardware problem but not software. | |
zte gx 761 after unlock still on np code | neeraj1st | Infinity-Box | 21 | 10-24-2010 00:09 |
zte gx 761 dead after complete formate | neeraj1st | Infinity-Box | 5 | 08-20-2010 16:11 |
ZTE GX-761 vodafone spain unlock probleme [ANSWERED] | yassinek85 | PolarBox 3 | 3 | 03-16-2010 23:19 |
zte x-761 dead with other box | sunnny | Infinity-Box | 5 | 01-10-2010 12:46 |
gx 15 dead FULL FLASH PROCEDURE.............. | hiteshhitesh | Sharp | 7 | 11-24-2005 19:54 |
