02-24-2009, 03:22 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | help infinity problem in s3 tuch calibrate module v2.77 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7803:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1.0.013_080306 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 48 sec Remove/Install battery now ! |
02-25-2009, 07:48 | #6 (permalink) | |
Banned Thanks Meter: 346 | Quote:
02-25-2009, 08:05 | #8 (permalink) | |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | Quote:
bro select mode 2 and calibrate tuchscreen | |
help infinity team in this kind of flash file.... | justine54 | Infinity-Box | 4 | 08-26-2009 15:01 |
Help This Problem In Blackberry 8700v | hans salim | BlackBerry (RIM) | 1 | 09-30-2007 12:58 |
plssss help big problem in sam e635 | odayking | UST Pro II | 2 | 07-25-2006 09:49 |
i help a problem in c330 | wichaigul | TotalMoto | 2 | 02-16-2005 16:45 |
plz help imei problem in sagem mw3020 | .::Moby World::. | Infineon C16X M51 & ARM7 M52 BASED | 1 | 07-03-2004 21:48 |
