06-15-2017, 10:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | Need help using SPD module I have problem using SPD module,at this time i need to flash Samsung E1270,select correct model and settings but get follwoing error while USB driver is also installed.As soon as i remove usb from phone software says Boot ok.What's wrong.I tried on diffrent PCs. Code: Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:453 8è~~ ¯È8¯Boot Ok |
06-15-2017, 11:50 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Code: Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:453 8è~~ ¯È8¯Boot Ok | |
04-01-2020, 18:02 | #5 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Quote:
Operation : Read NV [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00F8 0042 0016 0000 [0] Flash VEN : FIDELIX , FM25Q32 [0] Flash CAP : 00400000 Check data ... Reading NV ... Saved to : D:\Documents and Settings\Hugo\Ambiente de trabalho\gt-e1270\6530_NV_00010000.nv Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00F8 0042 0016 0000 [0] Flash VEN : FIDELIX , FM25Q32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Platform : MOCOR_W13.09_ERIC_R3.0.2_Debug sc6530_samsung_CaramelSS_EURO ExtInfo : LevelofLock 00000000 00000000 Project : SC6530_SAMSUNG HWInfo : SC6530_ERIC Compile : 01-29-2014 18:30:44 Set FileInfo : Model Vendor : Samsung Model Name : GT-E1270 ExtInfo Data : TMN Saved to : D:\InfinityBox\CM2SPD\Read_out\SPD6530_SAMSUNG_004 00000_MOCOR_W13.09_ERIC_R3.0.2_Debug_sc6530_samsun g_CaramelSS_EURO_01292014XXXXXX_TMN__Samsung-GT-E1270.bin Done! Elapsed: 00:01:04 Reconnect Power/Cable! | |
