09-17-2010, 16:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: MoviL GsM Age: 38
Member: 949016 Status: Offline Sonork: 161.7672 Thanks Meter: 25 | Need Help To Work This Phone Vertu F3+ |
09-18-2010, 09:24 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! what type connector is used in this phone? do you have pinfinder? are you sure that this phone is mt62xx family? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
09-18-2010, 13:23 | #6 (permalink) |
Member: 949016 Status: Offline Sonork: 161.7672 Thanks Meter: 25 | Hello I Just get My Pinfinder,But I Dont Know Use Good the Conector its like ZTE A36 And When I Type *#0044# Send It Change the Language to English,So I know Its Support By Infinity any help |
09-19-2010, 01:53 | #8 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | If you found the RX TX point on PCB solder them as this box Tx (RJ45 pin-2) to phone Rx point box Rx (RJ45 pin-3) to phone Tx point box GND(Rj45 pin 8) to phone GND point. then follow this..Infinity Box Video Tutorial If you not found a RX TX on PCB you have to check voltages on USB connecter for find the RX,TX. check this example. Explain to find pinout on 12 pin usb connector. 1. At first, you need to find GND signal (3pin-00.2v) 2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts: 1pin-0.00v - this pinout is wrong 2pin-2.78 - it may correspond to Tx Rx signals 3pin-00.2v - GND signal 4pin-2.75v - it may correspond to Tx Rx signals 5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT! 6pin-0.00v - this pinout is wrong 7pin-4.02v - this pinout is wrong 8pin-2.89v - it may correspond to Tx Rx signals 9pin-3.05v - this pinout is wrong 10pin-0.00v - this pinout is wrong 11pin-1.09v - it may correspond to Tx Rx signals 12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage 3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ). When the phone is POWERED ON, Tx with GND make a sound beep. When it is TURNED OFF, it shows 600-700 ohm. It is suggested to do all the job using wire connection. After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v. INFO:@Gsmtricks If you have pinfinder folow this ... Infinity Pinfinder user manual Then this.. Infinity Box Video Tutorial |
09-19-2010, 11:26 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
step by step procedure is completely described in pinfinder user manual | |
09-19-2010, 18:45 | #11 (permalink) | |
before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. press and Hold phone power button and start search. | |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
