11-06-2007, 15:06 | #1 (permalink) |
Insane Poster Join Date: Nov 2004 Location: C:\Program Files\ Age: 43
Member: 93992 Status: Offline Thanks Meter: 6 | Motorola C261 Reatart solution !!TESTED > error.4444444444444 > or Format FFS but phone still restart dan di flash ok but still Restart : Check Flash-1... SW version: 0.1.76 HW version: MOTOROLA_E58S LP ver: LPA3_0131 Flex ver: FLEX_90_64_2S03 cpu id: 08B6 imei eeprom: 35941600302914 required SW version: 0.1.76 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_xxxxxxxxxxxxxxx_20071031-225205.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 359 sec Remove/Install battery now ! <<<< still RESTART after flash and then unlock : Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C261 COM13 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 imei eeprom: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx sp-locked: 21902.24007. Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_xxxxxxxxxxxxxxxxxxxxxxxx x_20071012-162936.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok error: errorcode#50: eeprom can't be erased <<<<<<<<<< Finished, time used: 35 sec Remove/Install battery now ! if chek at backup system C:\Program Files\InfinityBox\Moto01 result is : >backup_eeprom_calibration_48484848484848_xxxxxxxx xxx34E.bin >backup_eeprom_ffs_48484848484848_xxxxxxxxxxxxxx.3 4E.bin >backup_eeprom_system_log_48484848484848_xxxxxxxxx xx.34E.bin >>>>> Solution : infinity force : flash dengan file : thick smart warite read imei from eeprom unthick Baudrate 921600 step 1 > Main = C261_0.1.32_Main_E58S_1135764463.34M.bin > lang pack = C261_0.1.32_LPA3_En_Indonesia_Tagalog_Th_Vn.34P.bi n > flex = C261_Flex_90_61_2K05_Locked_268-03.34F.bin > eeprom > eeprom_calibration_by GRAHACENTER_TEAM.34E.bin (silahkan download) > unlock >Done log: Loading file v.01... C261_0.1.32_Main_E58S_1135764463.34M.bin loaded Loading file v.01... C261_0.1.32_LPA3_En_Indonesia_Tagalog_Th_Vn.34P.bi n loaded Loading file v.02... C261_Flex_90_61_2K05_Locked_268-03.34F.bin loaded Loading file v.02... eeprom_calibration_by GRAHACENTER_TEAM.34E.bin loaded COM4 [VCP2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Write: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.32 HW version: MOTOROLA_E58S LP ver: LPA3_0132 Flex ver: FLEX_90_61_2K05 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20071106-200937.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Writing: Eeprom Write Done Finished, time used: 312 sec Remove/Install battery now ! Unlock Log after flashing : COM4 [VCP2] selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.32 HW version: MOTOROLA_E58S LP ver: LPA3_0132 Flex ver: FLEX_90_61_2K05 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20071106-201616.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 23 sec Remove/Install battery now ! step 2 flash eeprom only with infinity !! > eeprom_ffs_by GRAHACENTER_TEAM.34E.bin > eeprom_system_log_by GRAHACENTER_TEAM.34E.bin > unlock > Done > nyalakan akan muncul Flex Reloading ! kemudian ffs manager formating dan restart (phone still restart) don't worry Final Smart clip > change to compal model > option C261 > Repair eeprom > welcomeback! pass: bokong B.R GRAHACENTER CELLULAR indonesia |
The Following 6 Users Say Thank You to grahacenter For This Useful Post: |
11-06-2007, 17:42 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | to much langkahnya...: and I like your password.. but many thank with solution..always creative ps : I never fail c261 restart flashing with pure infinity....always work & tested... Br Pentil&bokong enak poll |
11-07-2007, 09:43 | #9 (permalink) |
Member: 93992 Status: Offline Thanks Meter: 6 | http://www.forum-indoflasher.com/vbb...4&d=1194380450 << this file eeprom_ffs_by GRAHACENTER_TEAM.34E.bin and please register ps: welcome at indonesia local forum |
09-09-2008, 02:07 | #10 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: tphcm Age: 42
Member: 178546 Status: Offline Thanks Meter: 17 | Quote:
09-09-2008, 07:27 | #11 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Tested with Infinity and smart-clip, both working fine..... |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
>>> Motorola C261 & C257: Change Band Solution <<< | RNC_EBM | Infinity-Box | 39 | 04-09-2009 18:50 |
UPDATE 03 Feb 2006: Motorola C261 model support | InfinitySupport | Infinity-Box | 43 | 06-05-2007 05:22 |
Finally Motorola C261 Direct Unlock Solution has been released | Infinity-Box | Motorola ODM | 0 | 05-22-2006 08:58 |
Motorola C261 | DJiCE | PolarBox 1 | 1 | 04-28-2006 15:21 |
unlock simlock motorola c261 | maxitel | Infinity-Box | 13 | 04-25-2006 11:35 |
