Old 06-11-2008, 02:34   #1 (permalink)
Member: 273705
Thanks Meter: 34
Unhappy Need help ZTC ZT199
I need eeprom from another similar phone(ZT199), after flash with ZTC-ZT199_TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_ W06_16_MP_V28_16m_En_Fr_Vn_Ru_Ar_Th.B0M ,format FFS and repair security area...phone don't start .. i don't have backup eprom.
COM44 [VCP10] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:5924:13A6
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EEA04D2E.[TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28.BIN_F9930C07].rpl
identification#1 detection finished
device-id: EEA04D2E
identification#1 protocol ver: 04
ver. sw1: TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28.BIN
ver. sw2: MAUI.05C.W06.16.MP.V28, F8F36C06
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28.BIN]_20080611-042940.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area#1 calculation...
done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_EEA04D 2E_TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16_MP_V28.BIN_F9930C07_20080611-042948.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_EEA04D 2E_TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16_MP_V28.BIN_F9930C07_20080611-043012.B0X.bin
Finished, time used: 225 sec
Remove/Install battery now !
Old 06-11-2008, 15:37   #2 (permalink)
Member: 148515
Thanks Meter: 14,661
hello!
are you sure that this version is your phone Original?
Old 06-11-2008, 16:45   #3 (permalink)
Member: 273705
Thanks Meter: 34
==== log opened: [6/9/2008 10:09:11 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.46
S/N: 2372:010F
Wait...
Done
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
baud set to: 19200
error: connection failed !
Operation failed !
Finished, time used: 80 sec
Power off phone now !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: TELSDA26_05C_HW
Software version: MAUI.05C.W06.16.MP.V
Software date: 2005.04.12
Barcode: 018010705301293
imei: 353079005929350
Finished, time used: 5 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
COM44 [VCP0] selected
Action: reset settings
19200 autodetect
CPU: MT6226
Connecting, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.05C.W06.16.MP.V28
Version: TELSDA26_05C_HW
detecting structure #2...
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 195
130 of 195 items cleared
0 items remains
Finished, time used: 325 sec
Action: imei
Connecting, wait...
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 353079005929358
imei verified Ok
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
done
60 byte(s) read
connection Ok
building list...
done
items total: 167
items to clear: 167
130 of 167 items cleared
items remains: 0
Finished, time used: 221 sec
Connecting, wait...
Finished, time used: 90 sec
Imei 35307900592935 already was repaired: 6/9/2008-10:18:26 PM
Continue with this imei ?
Action: imei
Connecting, wait...
imei verified Ok
Action: repair security area
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EEA04D2E.[TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28.BIN_BD7AF0CE].rpl
device-id: EEA04D2E
ver. sw2: MAUI.05C.W06.16.MP.V28, 310F8542
Write...
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_EEA04D 2E_TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06 _16_MP_V28.BIN_BD7AF0CE_20080609-223938.B0X.bin
Finished, time used: 136 sec
Old 06-11-2008, 21:59   #4 (permalink)
Member: 148515
hello!
we have a lot of this version files on our support area
flash your phone
Old 06-13-2008, 15:42   #5 (permalink)
Member: 273705
Thanks Meter: 34
hello!
first I want to thank you for your reply... I tried to write several flashes but without any success... at the last one the phone was booting but it didn't show anything on the screen ... after that I re-wrote TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 _MP_V28 and the phone powered on...I re-wrote the imei and now the phone functions just fine repairing also the fisrt problem ( phone restarting when simB was acquiring network )
Thank you very much ...infinity - best box of the year !!!
Old 06-13-2008, 21:43   #6 (permalink)
Member: 148515
hello!
focus on second MCU part.
format it and restore IMEI
Old 09-08-2008, 10:50   #7 (permalink)
Member: 104603
Thanks Meter: 13
How can format second MCU ?
Old 09-08-2008, 19:02   #8 (permalink)
Member: 148515
hello!
assemble cable with second MCU pinout and repeat format FFS procedure and then IMEi restore
Old 09-09-2008, 08:46   #9 (permalink)
Member: 104603
Thanks Meter: 13
hello again, move my question on http://forum.gsmhosting.com/vbb/show...51#post3638151
and thank.
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriousGold 66 08-27-2010 13:20
hello all i have ztc c2000 need help hanen Chinese Models & Cloned Phones 4 05-10-2008 00:43
Help Needed On Ztc F888 tanmaykurtkoti MC-Tool 0 03-31-2008 14:42
Newbie needs help with ZTC 6668 / Smile warasha Chinese Models & Cloned Phones 2 03-18-2008 08:16
ZTC-ZT199 Pinouts 10000% ok tested farhanali Infinity-Box 10 01-21-2008 09:59
Page generated in 0.37232 seconds with 8 queries
