Old 11-22-2011, 00:16   #1 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 18
Need help with a ZTE G-X990
Hello, I need some help here. The thing is I received this zte model with aparently improper flashing because it showed Invalid IMEI.
I repaired it successfully and it received no radio coverage.
So decided to flash it, in case it had being incorrectly flashed with another box. I have downloaded 2 versions from the x990 support folder, I flash them, the process ends correctly but then it reports it can not find the FFS.
This phone has a NAND flash chip. When I try to format the ffs it seems as if it were trying to format a NOR flash chip.
I am posting the current state of the logs of MModule after reading general information. I need some clue or idea from support or some more experienced user to figure out if the phone has a defective flash ship, or the current version of MModule is not working this model properly or if I am selecting something wrong at the time of flashing:
COM4 [VCP0] selected
module v4.09
Device: ZTE-X990
Checking data, wait...
Action: read/check information
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (115200)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X990_V2_Z5_FR_D1EF111
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2 _Z5_FR_D1EF111
nfi area detection (3 cores) finished: Ok
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_ Z5_FR_D1EF111.BIN
project-id: X990_V2_Z5_FR_D1EF111, 00000000
code offset: 00000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
Disconnect...
done
Finished, time used: 49 sec
Remove/Install battery now !
There is a warning withing this log, almost at the end, that says it can not find the ffs area.
I am open to sugestions.
Br,
Zeddicus.
Old 11-22-2011, 18:50   #2 (permalink)
Member: 148515
Thanks Meter: 8,529
hello!
Phone is dead now?
Can we see format FFS log?
Old 11-23-2011, 01:07   #3 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 18
Follow up with G-X990
Hello,
Yes, phone is dead now. That is, it will not turn on, but if connected to the box via the USB port using my box integrated pinfinder L10C adapter it is detected and can be flashed.
I made another trial yesterday. I made a full format of FFS area, which did not report any error and flashed it again, but no response from the phone what so ever.
Here is log:
==== [21/11/2011 07:19:03 p.m.] ====
module  v4.09
Device: ZTE-X990
Action: erase whole flash chip
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect NAND info...
bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2_Z5_FR_D1EF111
TCL-ID detection...
rom info ver: 07
sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z5_FR_D1EF111.BIN
TCL-ID is absent
===>  done
Format...
00000000-03FFFFFF...
Format done
Disconnect...
done
Finished, time used: 1 min 0 sec
And more, the result of last flashing attempt after erasing whole flash chip.
==== [21/11/2011 07:22:03 p.m.] ====
module  v4.09
Device: ZTE-X990
Action: write flash NAND
write: Firmware
ZTE-X990_ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z9_ES_D1EF107_2010-06-13_En_Es.B4M_4.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2_Z9_ES_D1EF107
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
detect sec ro...
detect NAND info...
warning: nand header is empty: probably flash chip completely erased
warning: can not detect header
nfi area detection (0 cores) finished: failed
TCL-ID detection...
===>  done
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 27 min 46 sec
It still did not boot up and started after that.
How can I provide ffs log? If I try to use the file system tab it fails with an error.
Up to this point, I really do not know what else to do.
Br,
Zeddicus.
Old 11-23-2011, 02:05   #4 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 18
More information
Ok. Now, here is more log information, this time trying to format ffs using service tab, ffs: complete mode:
module  v4.10
Device: ZTE-X990
Action: reset settings ("format ffs") NAND
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
project-id: X990_V2_Z9_ES_D1EF107
detect NAND info...
TCL-ID detection...
rom info ver: 07
sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z9_ES_D1EF107.BIN
project-id: X990_V2_Z9_ES_D1EF107, 00000000
TCL-ID is absent
===>  done
warning: can not format: HW_STORAGE_NOR is not present
Format...
autodetection mode...
error: can not format: 0BDC:S_DA_INVALID_RANGE
Format...
error: last error: 0BDC:S_DA_INVALID_RANGE
Disconnect...
done
The way I see it, MModule seems to be trying to format a NOR flash chip, even when in the settings a NAND is selected and the program detects the following:
So, there is a NAND K9K1208X0C Samsung flash chip installed on the phone, not a NOR.
Br,
Zeddicus
Old 11-24-2011, 14:37   #5 (permalink)
YellowBoss's Avatar
Member: 1043909
Thanks Meter: 42,809
make "format ffs" with "safe" mode.
Waiting for results.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 02-25-2016 05:31
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.49620 seconds with 8 queries
