06-06-2015, 13:47 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Idea Fab 3G i4901 "Secure Boot" or "BootLoader Locked" phone It's Idea i4901. Operation : Check / Read Info [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 170 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Check / Read Info [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580DAA7463D0F7 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580DAA7463D0F7 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : compal ProdName : i4901 ProdModel : i4901 Device : i4901 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.17 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Read Flash [ v1.21 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580DAA7463D0F7 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580DAA7463D0F7 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : compal ProdName : i4901 ProdModel : i4901 Device : i4901 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.17 [Read Ok] : preloader_lf12_newpl.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lf12_newpl / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__compal__i4901__i4901__4.2.2__ALPS.JB3.MP.V1.17\ All done! Done! Elapsed: 00:03:18 Reconnect Power/Cable! |
06-06-2015, 13:59 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, what is problem in result? First log can be result of connection or battery problem as well. There is no any exactly though about that. |
06-06-2015, 14:55 | #3 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
When I Click On "Identify" Then I Connect With USB Cable & Insert Battery So It's Always Show "Secure Boot" or "BootLoader Locked" phone But When I "First" Connect Cellphone With USB Cable & Insert Battery Wait 2Sec "Then" Click On "Identify' So It's Show, Initial Info read Ok! | |
11-21-2015, 08:43 | #6 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Operation : Check / Read Info [ v1.37 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x2 LErr : 2001 Error! SECURE BOOT target! Check Model Settings! Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Check / Read Info [ v1.37 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475809AA8361D06B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034475809AA8361D06B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : compal ProdName : i4901 ProdModel : i4901 Device : i4901 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.17 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V11_P3_1_wg_n EXTRA : LCD [0] : hx8379a_dsi_vdo LCD [1] : otm8018b_dsi_vdo_wvga LCD Res : 800x480 TOUCH [0] : ektf2232 CAM [0] : s5k5cagx_yuv MODEM : cci72_we_tpe_jb3_hspa LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL ko_KR hdpi Done! Elapsed: 00:00:07 Reconnect Power/Cable! Want To Unlock "SECURE BOOT" If Someone Help Me Please. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
04-13-2016, 00:04 | #7 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, Every Day Getting This Cellphones With Virus Infected Or Hang At Logo. More R&D On It. One More Step For Searching Solution. Operation : Check / Read Info [ v1.45 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D4330344758181C9DEA512D Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758181C9DEA512D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : E20C0CE3B7E383081FCA05CC9FBE6A69 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : compal ProdName : i4901 ProdModel : i4901 Device : i4901 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.17 SECURITY : IMEI_SW [1] : 35362XXXXXXXXXX IMEI_SW [2] : 35362XXXXXXXXXX BTMAC Addr : 0016DXXXXXXX WiFi MAC : 0016DXXXXXXX MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V11_P3_1_wg_n EXTRA : LCD [0] : hx8379a_dsi_vdo LCD [1] : otm8018b_dsi_vdo_wvga LCD Res : 800x480 TOUCH [0] : ektf2232 CAM [0] : s5k5cagx_yuv MODEM : cci72_we_tpe_jb3_hspa LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL ko_KR hdpi Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : FastBoot : ReadInfo [ v1.45 ] Code: Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 23 ] Sync... BootLoader : Not Supported! Warranty : Not Supported! Secure : Not Supported! ExtraStat : Device have SECURED sub-model! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.45 ] Code: Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 23 ] Sync... BootLoader : Not Supported! Warranty : Not Supported! Secure : Not Supported! ExtraStat : Device have SECURED sub-model! Boot Lock/Unlock NOT required for that device! Done! Elapsed: 00:00:22 Reconnect Power/Cable! I Have Full Dump Read From Working Cellphone So Should I Try To Write On Faulty Cellphone ? Code: MT6572__COMPAL__i4901__ALPS.JB3.MP.V1.17__Android_4.2.2__24.06.2014.ispff |
04-13-2016, 05:46 | #8 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 44
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,419 | I Have Full Dump Read From Working Cellphone So Should I Try To Write On Faulty Cellphone ? Code: MT6572__COMPAL__i4901__ALPS.JB3.MP.V1.17__Android_4.2.2__24.06.2014.ispff Yes,if its the same preloader and version.then post result |
04-15-2016, 21:28 | #10 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, This Firmware & Full Dump Won't Help On This Cellphone. Request To All, Don't Try With Any Firmware Until We Get Safe Way To Flash It. |
04-16-2016, 12:54 | #11 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
So If U Have Readed Full File Kindly Share.... Or You Have Factory File Or Official Rom? | |
